Toggle Button For reverse
I have a command-based program with a DriveTrain subsystem that has this method:
void DriveTrain:: DriveDirectional(float x, float y){ robotDrive41->ArcadeDrive(y, x); //Call the ArcadeDrive Method using the Y //Axis as the speed and the x axis as the Turn. } How would I implement a command to have a toggle button (i.e. the joystick button) to set the robot in reverse (press button once, in reverse, press button again, back to moving forward)? Last edited by 414cnewq : 01-23-2016 at 01:33 PM. |
Re: Toggle Button For reverse
The space after the D in : DriveDirectoinal is not a glitch. The : D was turning into
when I posted the comment. |
import wpilib
class Button:
'''Useful utility class for debouncing buttons'''
def __init__(self,joystick,buttonnum):
self.joystick=joystick
self.buttonnum=buttonnum
self.latest = 0
self.timer = wpilib.Timer()
def get(self):
'''Returns the value of the button. If the button is held down, then
True will only be returned once every 600ms'''
now = self.timer.getMsClock()
if(self.joystick.getRawButton(self.buttonnum)):
if (now-self.latest) > 600:
self.latest = now
return True
return False
Here's some C pseudo_code: Code:
button_now = get_button(); // get the button state (pressed or not pressed)
if (button_now && ! button_previous) // detect rising edge only
{forward = ! forward;} // if rising edge, toggle the direction boolean
button_previous = button_now; // save the button state for comparison in the next iteration
As Ether said, you need to detect the "rising edge" of the button being held down. Here is a function I wrote for doing just this:
This function allows a boolean to be toggled with a joystick button, inside of a while loop that is constantly updating.
button: Joystick button for toggling.
buttonPressed: Boolean for tracking whether the button was pressed in the last cycle. This prevents toggleBool from rapidly switching states while the joystick button is held down.
toggleBool: Boolean to be toggled.
void Robot::ToggleBool(bool button, bool &buttonPressed, bool &toggleBool){
if(button && !buttonPressed){
buttonPressed = true;
toggleBool ? toggleBool = false : toggleBool = true;
}else if(!button)
buttonPressed = false;
ToggleBool(oJoystick->GetRawButton(JOYSTICK_BUTTON_REVERSE), reverseButtonPressed, reverse); |
