Go to Post Dave Lavery just responded to one of my posts. I think that I might die. - Karibou [more]
Unread 23-01-2016, 15:40
Brainiac98's Avatar
Brainiac98 Brainiac98 is offline
FRC #3528 (Up Next!)
Brainiac98 is an unknown quantity at this point
Using 2 USB Cameras
Hi everyone,
My team is having trouble figuring out how to use two of the Microsoft USB Cameras on one robot. We want to stream two camera feeds to SmartDashboard, but can't find any way to do so. I've heard elsewhere (I forget where) that with the wpilib USB camera code examples, there is no way to stream more than one. Is this still the case, or is there some way we can do this?
Thanks!
Unread 23-01-2016, 16:19
MooseGoose MooseGoose is offline
FRC #0610
MooseGoose is on a distinguished road
Re: Using 2 USB Cameras
We tried this and created a custom class of CameraServer with two different instances for the two cameras. It still didn't work spitting an internal error:
Error when starting the camera: cam3 cam2 IMAQdxError: -1074360319: Internal error at org.usfirst.frc.team611.robot.CameraServer610.star tAutomaticCapture(CameraServer610.java:209)
org.usfirst.frc.team611.robot.Robot.robotInit(Robo t.java:23)
edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72)
edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)
We traced this error and it seems to come from the National Instruments vision library which we don't have access to.
So I don't think there is a way to send two USB Camera feeds on the roboRio unless you process it externally and send it as one feed.
Unread 23-01-2016, 18:01
kmodos kmodos is offline
AKA: Alex
FRC #1126 (SparX)
kmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to behold
The snippet I posted here will allow you to stream from multiple cameras, but only view 1 at a time.
