Go to Post We also had a couple of student leaders emerge from this offseason Rumble, which can do nothing but help the team in the upcoming FRC season. - JesseK [more]
Unread 23-01-2016, 22:36
Chris_Elston's Avatar
Chris_Elston Chris_Elston is online now
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
More than one PCM (Pneumatic Control Module)?
I am wondering if anyone knows of any rules against running more than one PCM. I can't seem to find anything that says different. If we can run more than one PCM, what do you do with the extra compressor and pressure switch controls in the software? Is there a way to disable it and only use the additional PCM as a valve controller only?
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 23-01-2016, 22:46
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: More than one PCM (Pneumatic Control Module)?
There are no rules against running more than one PCM, provided only one is connected to the bottom of the PDP. (You can have up to 3 on a single PDP Wago circuit.)
Don't worry about the compressor circuit. If there's nothing connected to the pressure switch input, the compressor power won't be enabled, since the pressure switch is normally closed.
Unread 24-01-2016, 11:12
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Two things for this
1) In Begin/initialization, you need to ensure your PCM with the compressor is identified as the one with it attached.
2) Remember to change the CAN ID number of the other PCMs on the robot so they are all unique.
