Go to Post It truly is a Merry Vexmas! - Ginger Power [more]
Unread 26-01-2016, 17:43
jagow100's Avatar
jagow100 jagow100 is offline
FRC #3539 (Byting Bulldogs)
jagow100 is an unknown quantity at this point
Where to buy another ADXL362/ADXRS450 Gyro
We are quite satisfied with the ADXL362/ADXRS450 gyro that came in the First Choice package. However it seems that we are unable to get another one through digikey. The Analog Devices website only sells the actual gyro chip, which won't work for us. Where else can we buy the entire unit?
3539 Programming Lead
The Programming Lizard
Unread 27-01-2016, 21:33
jabackma jabackma is offline
FRC #3197
jabackma is an unknown quantity at this point
Re: Where to buy another ADXL362/ADXRS450 Gyro
how did you connect it? I see no documentation on the Analog Devices website, and see nothing on the wpilib either. We are using C++, I see no class code for it either...
Thanks.
Unread 29-01-2016, 07:38
jagow100's Avatar
It's super simple to hook it up. Just plug it into the SPI port on your roboRio. And for the whole WPILib thing, there's libraries for Java so I'm pretty sure there are libraries for cpp. In Java the library we use is the ADXRS450_Gyro. In cpp it might be the same but I'm not sure.
Unread 01-02-2016, 10:53
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
If you only need the gyro and would like something a bit easier to mount/wire remotely, Analog Devices sells an evaluation board for the ADXRS450. The part number is EVAL-ADXRS450Z. Photo below:
https://drive.google.com/file/d/0B6M...ew?usp=sharing
They're $54.38 at Digi-Key, almost free if you still have your $50 Digi-Key KOP voucher.
Unread 08-02-2016, 10:19
rod@3711 rod@3711 is offline
AKA: rod nelson
FRC #3711 (Iron Mustangs)
rod@3711 is an unknown quantity at this point
Is it really true that we cannot buy a copy of the ADXRS450-FRC that came in First Choice package. This was too easy to install and seems to work OK.
Now we can not buy a spare?
