Navx-MXP AHRS error
Our kauailabs Navx-MXP is giving an error in the DriverStation after deploying code and following set up instructions:
ERROR Unhandled exception instantiating robot org.usfirst.frc.team5510.robot.Robot java.lang.NoClassDefFoundError: edu/wpi/first/wpilibj/PIDSourceType at [com.kauailabs.navx.frc.AHRS.<init>(AHRS.java:187), com.kauailabs.navx.frc.AHRS.<init>(AHRS.java:319), org.usfirst.frc.team5510.robot.Robot.<init>(Robot.java:56), sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method), sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62), sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45), java.lang.reflect.Constructor.newInstance(Constructor.java:408), java.lang.Class.newInstance(Class.java:433), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:197)] Last edited by DanielAndrews : 27-01-2016 at 20:53. |
Re: Navx-MXP AHRS error
Your problem is that you are using the 2015 WPILib with a library that was designed for 2016. One of the things that changed in 2016 was that PIDSourceParameter was renamed to PIDSourceType.
Source: https://wpilib.screenstepslive.com/s...e-2015-to-2016 My recommendation is simply that you update your roboRIO, because you will have to do it eventually. |
oh, will do right now. Thanks!
Hi,
When I try to compile my navX code on Eclipse using C++ it says "fatal error: AHRS.h: No such file or directory" What can I do to fix it? Inconceivable Programmers |
