Go to Post I wouldn't recommend using steel because it will eat up your weight budget pretty quickly. - Scott Morgan [more]
Unread 29-01-2016, 13:44
H2O Enthusiast H2O Enthusiast is offline
AKA: Courtland
FRC #3039 (Wildcat Robotics)
H2O Enthusiast is an unknown quantity at this point
Question Good Cameras for Driving
Hey, we've been trying to find a good driving camera that our drivers can view on the smart dashboard. We've been using an Axis M1011 but we want to switch to something with a higher frame rate. Do y'all have any good suggestions for a camera we could use that has a decent frame rate and viewing angle? Thanks.
Unread 29-01-2016, 15:40
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Good Cameras for Driving
Just about any web cam should be able to deliver plenty more data than the radio link can handle. If you want a higher frame rate, you're going to have to send smaller images, whether through a smaller image size, tighter compression, image analysis/reduction, or a combination.
OBTW, I presume we'll see you at Bayou!
Unread 29-01-2016, 16:03
AKA: Courtland
Thanks for the advice! See you at Bayou!
