775Pro 2:1 Gearbox HELP
Hey guys, rookie here, just wondering how I would get a 775pro motor to a 2:1 gearbox. Preferred if it was swappable with a mini cim mount or a versa planetary for motor testing.
And how crazy would it be to run two 775 pros with 1:1 versa planetary gearboxes per 6" wheel on each side of a shooter? Rip up the boulder like crazy? ![]() |
Re: 775Pro 2:1 Gearbox HELP
I think 3:1 with 6" wheels shoiuld put you near the optimal range for shooting IIRC. I heard 2:1 to 3:1 on 4" wheels, so 3:1 on 6" wheels is still good.
I was going to try a 1:1 reduction with 4" wheels just to see if that worked later. |
Thanks for the quick responses! So would it be better (due to our extremely tight budget) just to stick with mini-cims as they spin at the same rpm as a 775 pro geared at 3:1 (6000 rpm) even though the mini-cims are heavier?
Assuming you drive the wheels off of the MiniCim shaft with no gearbox, then yes, that would be a much cheaper option. You are losing a good bit of power going to a Mini CIM though, so your shots may not go as far as a 775Pro geared to the same speed. The VersaPlenetary (or other Gearbox) opens up your options a lot, but at the cost of money.
How much difference would you estimate? (sorry for so many questions...)
So ideally you would be going 2/3 the output piwer of a 775pro (assuming many things like inertia not existing). If you are on a budget, it is much better to go miniCIM over 775pro, as gearboxes can double or triple the cost of a system. |
#7
We just received in the 775pro today and ran some testing tonight with the Vera planetary at 1:1 ratio.
We made a simple wooden jig with 2 motors assemblies spinning two 4x2 Colson wheels (flywheel style). It could easily launch the boulder 20+ feet. This was just a quick hookup to a FRC battery that was at 12.8v. We had not planned on using these for our shooter as we have something else planned. Since the thrown together jig showed such promise we are going to go ahead and building an optimized (aluminum) jig with the control system. We be incorporating the Versa encoder kit with talon and really see what it can do when optimized. I will try to upload the video from tonight sometime this weekend. So far I like the motors, we shall see, the encoders are next... Aloha! |
#8
Although we are leaning towards the 2.4:1, I am definitely looking forward to seeing that video!
#9
I would urge you to not run 1:1 shooter with a 775 or 775pro. The motors don't have enough torque for this and will be overloaded. During prototyping, we overheated a 775 that way running an 6 inch single wheel shooter. It pegged our power supply current limit at 30 amps at 10 volts for 300 watts. Launch power actually seemed less than same motor with a 3:1 versaplanetary, which took 15 amps at 12 volts for 180 watts.
A 775pro with 3:1 versaplanetary outperformed both by a wide margin. I measured 5340 RPM at the wheel, so 16020 RPM at the motor. This is near the motor's peak efficiency, so motor heating is not an issue. The versaplanetary gets hotter than the motor due to the extremely high RPM. Current Draw was 16 amps at 12 volts for 192 watts, though the analog ammeter may not be super accurate. With the right compression but otherwise imperfect mounting, this setup launched boulders more than the required distance. The suggestion of a CIMile for 2.41:1 would work, and I estimate you'd get maybe 6800 RPM at the wheel. External 2:1 reduction with chain or belt should work too, resulting in maybe 8000 RPM. I'd be curious to hear what actual wheel speeds you achieve. Keep an eye on temps and beware wheels and tread material coming apart at high speed. |
#11
![]() Last edited by pilleya : 30-01-2016 at 01:16. |
#12
I would use a 1:1 Versaplanetary and get the 2:1 reduction using chains or belts.
#13
You could use a Vex CIM-ile. The reduction is 12/29 which is pretty close to what you are looking for.
#14
Or just use a CIM-ile and then a 8mm to 1/2 inch hex adaptor http://www.vexrobotics.com/217-3255.html http://www.vexrobotics.com/vexpro/mo...s/cim-ile.html |
#15
Edit* just saw the post above that answered this question lol |
