Go to Post I'm so conflicted right now. On one hand, you made the same page as a celebrity. On the other hand.... Justin Bieber. - Akash Rastogi [more]
Unread 30-01-2016, 10:30
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
Maxbotix not working well with RoboRIO?
Hi,
We are trying to use the Maxbotix 1013 ultrasonic sensor but when we put it on the Rio, the range of values we get is just 233 to 350. On our arduino, we get a range of about 58 to 400ish. We were using the analog inputs on the arduino and on the Rio. All we are doing is analog.input() on the Rio. We are using pin 3 on the maxbotix sensor. Is that the actual range of the sensor? Or am I doing something wrong.
Thanks a bunch in advance!
Unread 30-01-2016, 10:50
jajabinx124's Avatar
jajabinx124 jajabinx124 is offline
Team 2052 Alumnus
AKA: Kshitij Wavre
jajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond repute
Re: Maxbotix not working well with RoboRIO?
Post some code?
You can find the actual range limit and the width of the ultrasonic soundwaves when you look at the data sheet for the sensor.
FRC Volunteer CSA (MRI off-season event, 2017 Lake Superior Regional, 2017 10,000 Lakes Regional) 2016 - Present
FRC 2052 KnightKrawler (Team Captain, Strategist, Scouting, Programming) 2013 - 2016
1 Division Win & Einstein Appearance
3 Division Quarter-Finalists
1 Regional Chairman's Award
5 Regional Wins, 3 Regional Finalists
3 MN State Championship Wins, 1 MN State Championship Finalist
Thanks to all our alliance partners who krawled with us: 41, 70, 225, 525, 1595, 2054, 2062, 2122, 2175, 2227, 2472, 2526, 2883, 2990, 3018, 3244, 3276, 3310, 3313, 3360, 3538, 3692, 4011, 4198, 4536, 4607, 4778, 5172, 5690
Unread 30-01-2016, 12:15
team-4480's Avatar
Debug? What's that?
FRC #4480
Originally Posted by jajabinx124 View Post
Post some code?
The code is as simple as it comes:
#in init code
ultrasonic = wpilib.analog.input(3)
#in teleop
print(ultrasonic.getValue())
I see on the datasheet that it is supposed to be able to output 0 to 1023 for analog, but since I get nothing close to that, does that mean my sensor has gone bad or something? Thanks!
Unread 30-01-2016, 12:26
Team 2052 Alumnus
AKA: Kshitij Wavre
#in init code
#in teleop
Possibly. Try using ultrasonic.getVoltage() instead of getValue() and see what you find- this method returns the analog value in calibrated units. (maybe this is what the data sheet is referring to when it says analog voltage bits values should be in between 0-1023)
Unread 30-01-2016, 13:18
team-4480's Avatar
Debug? What's that?
FRC #4480
Yeah I think the sensor is just not working. The voltage only changes for about 18 inches in range which is not even close to what it should be doing(5 meters). I think I'll give some other types of ultrasonic sensors a try. Thanks for the help!
Unread 01-02-2016, 13:35
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
The RoboRIO has a 12-bit ADC, not a 10-bit ADC. The RoboRIO's ADC count value can range from 0 to 4095. You can right shift that value by 2 to get a value in the range from 0 to 1023.
Each count will relate to 5mm of range. So multiply that output by 5mm to get the correct distance.
The beam pattern of that ultrasonic sensor is wide. That means that anything near it's cone will cause a reflection. The floor or table counts.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
