Go to Post It's not pink enough, I don't beleive it! :p - Lil' Lavery [more]
Unread 01-30-2016, 12:59 PM
urg8rb8 urg8rb8 is offline
FRC #0108
urg8rb8 is an unknown quantity at this point
Can't get driver station to keep robot code light to stay green
Robot communications light stays on but the robot code light stays green for like two seconds then turns red. We put printf calls in RobotInit() and Disable() and we see both prints in NetConsole. This tells me that the code is actually being executed by the roborio but why is the Disable() function being called?
We've been at this for a few days and can't figure it out. We've made sure all the pieces of SW have been updated to the latest versions.
Thanks for your help!!
Unread 01-31-2016, 01:42 PM
axton900's Avatar
axton900 axton900 is offline
Programming Co-Captain
FRC #1403 (Cougar Robotics)
Rookie Year: 2015
axton900 has a spectacular aura aboutaxton900 has a spectacular aura aboutaxton900 has a spectacular aura about
Re: Can't get driver station to keep robot code light to stay green
If you do not have a SendableChooser object, HAL does not initialize. Try this and see if your code works
Unread 02-01-2016, 11:57 PM
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Disable() gets called on startup so that you can do the things required to "disable" if there's anything special you'd like to do. Some questions...
Do you ever get the chance to click on "Enable" at the driver station? Or is it dead by then?
If it's dead so quickly, (the green robot code isn't lit) this means the program crashed and the best way to catch a crash is with the debugger. Take a look at screensteps live for "how to debug" ... but the gist is that rather than "Run As...->WPILib", you should use "Debug As...->WPILib" and this will deploy the code, but it will then launch it via the gdb debugger. If you're fortunate, the crash (exception) will get caught by gdb and you can pretty easily tell where the crash is.
To give you a hint of the type of thing I've seen make an early crash pre-enable with my students is not understanding declaring pointers and when they can be used. For instance, at the definition of your "SimpleRobot" class, if you declare a pointer and then try to use the pointer before instantiating it (via 'new'), you'd be using a null pointer. Things like...
class MyRobot : SimpleRobot {
  Victor *pMotor;
  int curSpeed = pMotor->Get();
In this case, curSpeed should be declared but not used in that way. It should be used in some place like RobotInit() AFTER doing a pMotor = new Victor(1);
There are many ways to make such an early crash - this is just an example. Give the debugger a try (its a great and valuable tool to know how to use) and if you're still stumped, post your code and we'll take a look for what might be at issue.
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
