Go to Post All I need now is a plow atachment for this year's robot - team 3311 [more]
View Poll Results: Is your team planning to go under the low bar?
Yes 410 87.61%
No 58 12.39%
Voters: 468. You may not vote on this poll
Unread 30-01-2016, 13:20
jlee0119 jlee0119 is offline
FRC #2849 (Ursa Major)
jlee0119 can only hope to improve
Low Bar
Unread 30-01-2016, 14:12
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Low Bar
I am not surprised that most/all teams are saying they plan to go under the limbo bar.
The problem will be that about a week from ship date (bag date, whatever), teams will start to discover that their robot won't be able to scale the castle as they had planned or won't be able to open the Sally Port as planned or won't be able to shoot into the high goal as planned and still be able to limbo.
Then comes the hard decisions. Do they keep the limbo and just not do those things they had planned or do they add some feature to their robot that allows the skill but disallows the limbo?
I could be wrong but I think at best we'll have 50% limbo bots once you exclude robots that have no other skills beyond just being able to limbo.
Callin' 'em as I sees 'em.
Dr. Joe J.
Team #88, TJ2
Unread 30-01-2016, 14:20
wjd13 wjd13 is offline
FRC #4905 (Andromeda One)
Rookie Year: 2015
wjd13 is an unknown quantity at this point
Re: Low Bar
I agree with Joe, teams will probably get to crunch time and have to decide whether it is still worth going under the low bar or using one of their other mechanisms.
<sidestory> Joe, my Dad (Patrick who works in Tech Org at iRobot) and I were talking about you and your thoughts on the competition at literally the same moment you posted your reply. Crazy right? Go iRobot!</sidestory>
Unread 30-01-2016, 16:11
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Low Bar
Yup, we decided to not try to put any mechanisms on our robot, aside from a simple ball collector/shooter that will fit under 15" at the center, 12" at the ends. The shooter might hit the high goal. It will hit the low goal.
If we get ambitious, we might think about adding another mechanism...but so far, no one on the team has presented any feasible ideas for how to do the other parts of the game.
Unread 30-01-2016, 16:48
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
Re: Low Bar
We are going under the low bar, and after doing the math, our original design to hang will not be strong enough. We will probably end up removing that part of the robot and worry about the shooter. We designed a shooter that can shoot 16 feet (atleast), and consistently make it in.
Unread 30-01-2016, 18:42
Dezion's Avatar
Dezion Dezion is offline
Coach | Strategy Co-Lead | Raawr!
FRC #4935 (T-Rex)
Rookie Year: 2015
Dezion is an unknown quantity at this point
Re: Low Bar
For those who are planning on going underneath the low bar, are you considering scaling the tower? If so, how important compared to other objectives do you consider having the ability to do both? Currently, are robot will be capable of going underneath the low bar easily, however we're unsure if we would like to scale the tower as well (partially due to time too).
Unread 30-01-2016, 19:08
bearbot's Avatar
bearbot bearbot is offline
FRC #2849 (ursa major)
bearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nice
Re: Low Bar
As week 3 ended our team has went under the low bar and several of the defenses. We have current plans for several prototypes that could also scale the tower. We have set a priority to fine tune our shooter and defenses. But will be a tight fit but we do have a spot to scale the tower.
FRC Events:
Chesapeake Regional Rookie inspiration award 2009
Offseason Event:
Battle O'BAltimore Champions 2010
FRC Teams :
2849 Ursa Major (Student 2009-2011) (Mentor2011- Current)
5979 (Mentor 2015-Current)
Unread 30-01-2016, 20:43
MrForbes's Avatar
AKA: Jim
Re: Low Bar
The low bar is one defense you can get relatively easily with a short height robot. It's also kind of the path back to get another boulder. We think it's kind of important, since it can speed up your cycle time, and help you get enough defenses and score enough boulders to possibly get you two ranking points. Scaling is ten points, and it could be an easy ten points if you're clever enough to make a good scaler....but we haven't figured out how yet, and really see the other parts of the game as being more important to do quickly.
It will be interesting to see how this all plays out...
Unread 30-01-2016, 20:49
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Low Bar
These short robots are also light. A removable scaling mechanism should be doable for many and still be under 120lbs.
Unread 30-01-2016, 21:47
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Low Bar
We are building a low bot that will scale, shoot H/L goal and cross all defenses, in theory. We'll see week 1 if it all works, I think it will. Plus we have an awesome auto planned
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star #21 | Galileo Division #91
Unread 31-01-2016, 10:43
cait.schroeder's Avatar
cait.schroeder cait.schroeder is offline
FRC #0375 (Robotic Plague)
Rookie Year: 2015
cait.schroeder is an unknown quantity at this point
Re: Low Bar
That is good in my opinion because if it is a conistent shooter and other teams are less geared toward shooting in the high goal but can scale and break defenses you will have a good matchup.
Unread 30-01-2016, 23:23
Billfred's Avatar
Billfred Billfred is offline
Re: Low Bar
Dr. Joe J.
We already almost had this with Robot in 3 Days--late Monday night, the Team Cockamamie robot sprouted a new piece to lower the Cheval de Frise or raise the portcullis. All of a sudden, the low bar became verrrrrrry tricky to manage, usually with a little bumping. Teams had better beware.
Unread 31-01-2016, 02:53
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: Low Bar
Can those robots going under the low bar still:
-Scale?
-Shoot high?
-cross all defenses (except maybe C because no one seems to care)?
-get a 2 boulder autonomous?
-all those answers at the same time?
That is where it gets interesting!
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 31-01-2016, 07:40
sagi34 sagi34 is offline
FRC #2231 (OnyxTronix)
sagi34 is an unknown quantity at this point
Re: Low Bar
-Scale?
-Shoot high?
cross all defences and get a 2 boulder autonomous (which I think is almost impossible without crossing the middle line) isn't about the height of the robot in my opinion.
I think that shooting high is a bit harder, but still lots of teams will do it.
the main problem will be scaling, it is very hard to put almost 2 meters of climbing mechanism into 40 cm robot (sorry for metric system lol), especially if you want to shoot high and scale the tower.
you will see the best teams do it all, but I think that it will be 20 teams max.
Student: 2013 - 2015
Mentor since 2016
Unread 31-01-2016, 09:25
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Low Bar
As always, we started wanting to do everything. Scaling went first. Having the low bar available for the go-to boulder cycle was far more important. Note that we must be in a certain configuration (not starting configuration) to make the low bar. It is a configuration we will naturally have after loading and before launching a boulder, so it shouldn't slow us down.
Edit: I realize now that this is misleading. Our primary design goal is to be a sapper bot (knock out defenses), but we also recognize that the only "unlimited" points in the game come from scoring boulders in the tower. As such, we have as a close second requirement to be able to score in the high goal, preferably over a tall defending robot, which (as a low bar robot) means a high, relatively slow launch angle. After working through a drive train design (weeks 2 and 3 mostly) this is where most of our skull work is going. Pickups are a well enough understood question that we are designing them to also work the category A defenses (portcullis and cheval de frise).
