Go to Post Wow, an entire thread with positive comments. I must be on the wrong forum... but my URL still says chiefdelphi.com. Hmmmm... - Chris Hibner [more]
Unread 30-01-2016, 15:23
tiernan12992's Avatar
tiernan12992 tiernan12992 is offline
LabVIEW Coding Captain and Weirdo
AKA: Tiernan Pierce
FRC #4490 (TechRaiders)
Rookie Year: 2015
tiernan12992 is an unknown quantity at this point
"Hooked" on this thread
Hello from Team 4490!
We are using a ladder-like mechanism to pull ourselves up the tower and we have steel hooks atop this ladder.
If anyone has any hooks which they have used or hook ideas for us to use, it would be greatly appreciated as we are looking for a new design that will not bend as these do. The robot appears too heavy for the hooks.
When I say hook ideas, I am referring to designs or references to websites/forums where there are examples of different hooks to use.
Thank you again for your help!
Last edited by tiernan12992 : 30-01-2016 at 15:26. Reason: Revision of my previous wording.
Unread 30-01-2016, 15:58
AKA: Tiernan Pierce
Rookie Year: 2015
Re: "Hooked" on this thread
I managed to find a set of hooks that would go perfect honestly. So... I suppose that this thread can now just be used for general discussion of hooks and things of the like?
Just do whatever it is that you do.
http://www.amazon.com/gp/product/B00...A2RNBXAVQ4OOHG
Unread 30-01-2016, 16:42
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
What is the weight capacity for those? If your robot is 140lb (120 + battery and bumpers) you might bend them.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 30-01-2016, 17:57
AKA: Tiernan Pierce
Rookie Year: 2015
We have no real way of properly testing it, so we used a teammate. That teammate being me, who weighs in at ~152. So... There is that. It could hold me up with no bending or any movement at all actually.
I guess that is a start.
Unread 30-01-2016, 19:50
TerryS's Avatar
TerryS TerryS is offline
FRC #2445 (RoboKap)
TerryS is an unknown quantity at this point
This is the hook we used to lift our robot up the steel pipe tower in Rebound Rumble:
https://grabcad.com/library/first-ro...-rumble-hook-1
The model doesn't show the screws used to hold the plates together.
It was made from 6061 aluminum using a bandsaw, grinder and hand tools. The hook worked fine. A similar hook should work this year.
"Genius is 1% inspiration, 99% perspiration"~Thomas Alva Edison
2016 Hawaii Regional Winners
Unread 30-01-2016, 23:41
pfreivald's Avatar
AKA: Patrick Freivald
We made excellent hooks on our 2010 robot by cutting them out of 1/4" aluminum plate. A bit of a pain, but with adequate stock you can do a lot of playing around to make sure they're exactly how you want them.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 31-01-2016, 01:15
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
We made a single hook out of 1/8 aluminum and it holds my weight with minor deformation (175 pounds)
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 31-01-2016, 08:17
pfreivald's Avatar
We found that .125" has too much deformation on a twist, and twisting when you don't want to twist is far too common in FRC. (Stupid dance music....)
We were also concerned about whether or not .125" would bite into the bar and cause damage that would Red Card a robot.
Team 1551
I write books, too!
Unread 31-01-2016, 08:25
Drive Coach
AKA: Antoine L.
The RUNG is made out of steel. I don't think an aluminum hook could cause any visible, let along serious dammage
Unread 31-01-2016, 08:52
pfreivald's Avatar
If fifteen years of FIRST has taught me anything, it's that if it looks like it might be a problem, you at least need to consider it.
Team 1551
I write books, too!
Unread 31-01-2016, 09:48
Drive Coach
AKA: Antoine L.
I cannot argue with that!
Unread 30-01-2016, 16:44
Chris Mounts's Avatar
Chris Mounts Chris Mounts is offline
FRC #1188 (Oaktown Crewz)
Chris Mounts is an unknown quantity at this point
We're planning on using either one or two of these:
http://www.homedepot.com/p/Tornado-4...8034/202639947
I think the 40 lb. limit is for the wall anchor not the hook itself. So far we've tested a single hook to 100 lb. without issue.
