Go to Post Sorry [the easy button] does not exist in robotics :D - Arkorobotics [more]
Unread 01-02-2016, 17:28
Jayd009's Avatar
Jayd009 Jayd009 is offline
AKA: Jonathan
FRC #4468 (Fernbank LINKS)
Rookie Year: 2016
Jayd009 is on a distinguished road
Using GRIP to launch Boulders
Hello,
My robotics team is thinking about using GRIP to launch a boulder during autonomous. We have an axis camera and I have a couple of questions.
1) Is it better to run GRIP on the roboRIO or should we run it on the driver station laptop?
2) Is it possible to use GRIP so that when the robot picks up the right image of the high goal it shoots a boulder?
3)What do each of the values that are published in contoursreport mean?
Thanks!
Unread 02-02-2016, 11:02
wazateer1 wazateer1 is offline
FRC #3506 (YETI Robotics)
wazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to behold
Re: Using GRIP to launch Boulders
Hey Jayd!
1) As a fair bit of warning, our team tried to run GRIP on the RoboRIO and it worked... for 4 seconds before it ran out of memory/cpu/generally crashed. If you are using the Axis Cam, you *should* be able to use the Add Ip Camera feature on the driver station.
2) Yes! If your robot scans network tables in teleopPeriodic(), and then calls fire() or Scheduler.runCommand(new Fire()) or whatever you like when you see a contour that "matches" the goal
3) Everything is measured in pixels
CenterX: coordinate position of X center of the contour
CenterY: coordinate position of Y center of the contour
Area: # of pixels the contour "contains"
Height: of the contour
Width: of the contour
