Go to Post An extra week of driving practice and shakedown outweighs a lot of ooo-shiny. - Billfred [more]
Unread 02-02-2016, 13:32
TimTheGreat's Avatar
TimTheGreat TimTheGreat is online now
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
"Stall" a motor
Is there a way to make an am-2971 motor resist motion? I know we can set the motor to spin one way, but I don't want to risk browning out. Any ideas?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 02-02-2016, 13:37
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: "Stall" a motor
You can use a sensor (potentiometer, encoder, etc) to determine where the motor is, and use a control loop (PID, bang-bang) to keep it at that position.
Now, if there is a lot of weight on that arm / mechanism, you likely don't want to be stalling your motor, gearbox, etc. You could easily damage the components or brown out, as you said.
From a programming perspective, the sensor+control loop works, from a design one, be cautious of an application that requires this to keep something in the air. Could be fine, but be sure you're not headed down the wrong road.
All opinions are my own.
Unread 02-02-2016, 13:40
JohnFogarty's Avatar
AKA: @doctorfogarty
Re: "Stall" a motor
Let me see if I understand your intention correctly first. You want to create a state in which your motor does not back-drive?
There are two methods commonly used by tricks with mechanical and software.
There are multiples of methods for mechanically preventing a motor from back-driving, gear wrenches, some worm gears (efficient), and latching systems.
In software the most commonly used method is through PID positional control in which you control the movement of the motor towards a "setpoint" and then the software then applies incremental power when needed to keep the motor at the positional set-point.
John Fogarty
