Microsoft USB Camera Error
We are trying to use a Microsoft Lifecam HD-3000 as a usb camera through the roborio. We have been using the code from the simple vision example:
CameraServer::GetInstance()->SetQuality(50); CameraServer::GetInstance()->StartAutomaticCapture("cam0"); However, once we start the driver station we get this error: at /opt/GenICam_v2_3/bin/Linux_armv7-a/libstdc++.so.6(+0xa2cb0) [0xb5e77cb0]Error on line 207 Incompatible State: The operation cannot be completed: Choose "USB Camera HW" on the dashboard at CameraServer::Serve() We have eventually gotten the camera feed to show up in java dashboard, but only after creating a couple of different camera objects and then restarting the dashboard. Otherwise it just comes up as connection reset or robot has stopped returning images. Any advice? |
Re: Microsoft USB Camera Error
We debugged this problem (we had it too) and discovered that it's because CameraServer expects all client information to arrive in one packet. The dashboard sends it in 2 packets, so CameraServer thinks part of the information is missing. You can find our fix for this here.
Thanks, a little bit confused on where to put the code though. Does it go inside of a header file?
Hey, same problem, appreciate the solution. Where is this file to fix it?
FYI, this seems to be a known error:
https://usfirst.collab.net/sf/go/art...4549746553 31 |
I would also recommend not using automatic capture. Grab your images using IMAQdx and call SetImage directly. |
#7
When using the USB Cameras I would suggest not doing automatic capture. The following is something I made that works. This code is for toggling between two USB cameras, because we have a front and back cam.
CPP File: Code:
* LHSVision.cpp
* Created on: Jan 26, 2016
* Author: Michael Conard
* THING TO CHECK:
* -In Internet Explorer, roborio-4237-frc.local,
* confirm the camera names in Silverlight. These
* should be "cam0", "cam1", or "cam2".
* -These names can be adjusted in the CAMERA
* namespace.
#include "WPILib.h"
#include "LHSVision.h"
namespace XBOX //Joystick Constants
const int NODE_ID = 1;
const int XBOX_A_BUTTON = 1;
const int XBOX_X_BUTTON = 3;
const int XBOX_LEFT_X = 0;
const int XBOX_LEFT_Y = 1;
namespace CAMERA //Camera Names
const char* CAM_ONE = "cam1";
const char* CAM_TWO = "cam2";
//NOTE: Camera 1 is the default camera. Can toggle to 2 later.
LHSVision::LHSVision(RobotDrive* pRobot, Joystick* pXbox) //Constructor
printf("File %18s Date %s Time %s Object %p\n",__FILE__,__DATE__, __TIME__, this);
frame = imaqCreateImage(IMAQ_IMAGE_RGB, 0);
IMAQdxOpenCamera(CAMERA::CAM_ONE, IMAQdxCameraControlModeController, &session);
Wait(.5);
IMAQdxConfigureGrab(session);
Wait(.5);
IMAQdxStartAcquisition(session);
Wait(.5);
frame2 = imaqCreateImage(IMAQ_IMAGE_RGB, 0);
mRobot = pRobot;
mXbox = pXbox;
LHSVision::~LHSVision() //Destructor
delete mXbox;
delete mRobot;
//Used for closing and stopping acquisition of a camera
void LHSVision::StopCamera(int camNum)
if(camNum == 1) //Camera 1 Shutdown
IMAQdxStopAcquisition(session);
Wait(.01);
IMAQdxCloseCamera(session);
else //Camera 2 Shutdown
IMAQdxStopAcquisition(session2);
Wait(.01);
IMAQdxCloseCamera(session2);
//Used for opening, configuring, and starting acquisition of a camera
void LHSVision::StartCamera(int camNum)
if(camNum == 1) //Camera 1 Startup
Wait(.01);
Wait(.01);
Wait(.01);
else //Camera 2 Startup
IMAQdxOpenCamera(CAMERA::CAM_TWO, IMAQdxCameraControlModeController, &session2);
Wait(.01);
IMAQdxConfigureGrab(session2);
Wait(.01);
IMAQdxStartAcquisition(session2);
Wait(.01);
//Send image to FRC PC Dashboard
void LHSVision::SendToDashboard(Image *image)
CameraServer::GetInstance()->SetImage(image);
void LHSVision::UpdateVision() //by Michael
if(mXbox->GetRawButton(XBOX::XBOX_A_BUTTON) == true) //Toggle on A button press
while(mXbox->GetRawButton(XBOX::XBOX_A_BUTTON) == true) //Prevents multi-press
if(send == 1)
StopCamera(1); //Stop Cam 1
StartCamera(2); //Start Cam 2
printf("\nActivating Camera 2 - Raw Image Display\n\n");
send = 2;
else
StopCamera(2); //Stop Cam 2
StartCamera(1); //Start Cam 1
printf("\nActivating Camera 1 - Raw Image Display\n\n");
send = 1;
if(send == 1)
IMAQdxGrab(session, frame, true, NULL);
SendToDashboard(frame); //Send Cam 1
Wait(.1);
else
IMAQdxGrab(session2, frame2, true, NULL);
SendToDashboard(frame2); //Send Cam 2
Wait(.1);
* LHSVision.h
* Created on: Jan 25, 2016
#ifndef LHS_VISION_H
#define LHS_VISION_H
class RobotDrive;
class Joystick;
class LHSVision
public:
LHSVision(RobotDrive*, Joystick*); //Constructor
~LHSVision(); //Destructor
void SendToDashboard(Image*); //Send Image to Dashboard
void UpdateVision(); //Toggle and Display Camera
void StopCamera(int); //Close Specified Camera
void StartCamera(int); //Start Specified Camera
private:
IMAQdxSession session;
Image* frame;
IMAQdxSession session2;
Image* frame2;
RobotDrive* mRobot;
Joystick* mXbox;
int send = 1;
#endif
* Robot.cpp
* This program requires:
* -XBox Joystick
* -Left Drive Talon
* -Right Drive Talon
* -Two USB Cameras on Roborio
* Ports can be adjusted below in PORTS namespace.
* Controls:
* -Forward/Reverse, Left Y Axis
* -Rotating/Spinning, Left X Axis
* -Toggling Front/Back Camera, A Button
* Info: The cameras display to the FRC PC Dashboard.
* To open this: FRC Driver Station -> Third
* Tab (Setup) -> Set "Dashboard Type" to "Default"
* In the FRC PC Dashboard near the bottom-middle,
* change "Camera Off" to "USB Camera HW".
#include "WPILib.h"
namespace PORTS //Motor Constants
const int LEFT_MOTOR = 0;
const int RIGHT_MOTOR = 1;
class Robot: public SampleRobot
private:
RobotDrive* mRobot; //RobotDrive with two Talons
Joystick* mStick; //Joystick
LHSVision* mLHSVision; //Raw Image Display
public:
Robot(); //Constructor
~Robot(); //Destructor
void OperatorControl(); //Can Drive and Toggle Cameras
void Autonomous(); //No Content
Robot::Robot() //Constructor
mRobot = new RobotDrive(PORTS::LEFT_MOTOR, PORTS::RIGHT_MOTOR);
mStick = new Joystick(XBOX::NODE_ID);
mLHSVision = new LHSVision(mRobot, mStick); //LHSVision requires a RobotDrive and Joystick
Robot::~Robot() //Destructor
delete mRobot;
delete mStick;
void Robot::OperatorControl() //Driving and Camera Toggling
while(IsOperatorControl() && IsEnabled())
mRobot->ArcadeDrive(mStick->GetRawAxis(XBOX::XBOX_LEFT_Y), mStick->GetRawAxis(XBOX::XBOX_LEFT_X));
mLHSVision->UpdateVision();
Wait(0.02);
void Robot::Autonomous() //No Content
while(IsAutonomous() && IsEnabled())
printf("Autonomous!\n");
START_ROBOT_CLASS(Robot)
