Go to Post You do realize that you all started jumping to conclusions without asking first which JVN he was talking about. - Jay H 237 [more]
Unread 04-02-2016, 12:02
Team DRIFT Team DRIFT is offline
FRC #4091
Team DRIFT is an unknown quantity at this point
How to Write From SmartDashboard
This sounds like a really stupid question, and it is. Quite simply, we can't figure out how to use the SmartDashboard to input information into our program. Our SmartDashboard.putNumber() works perfectly fine, but when we try using the .getNumber() or .getBoolean(), or any of the gets, nothing happens. If we don't set a default value, no value is set.
For printing on the SmartDashboard, we are simply using the methods in our code, and the corresponding widgets are automatically created.
Unread 04-02-2016, 12:21
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: How to Write From SmartDashboard
You have to first put the value to the SmartDashboard before you can get its updated value. So, you call SmartDashboard.putNumber("this is a number", some_default_value), which causes the field to appear on the SmartDashboard. Then you can edit this number in the SmartDashboard GUI, and when you call SmartDashboard.getNumber("this is a number"), it will return the updated value.
Unread 04-02-2016, 22:13
snekiam snekiam is offline
FRC #3322 (Eagle Imperium)
snekiam has a spectacular aura aboutsnekiam has a spectacular aura aboutsnekiam has a spectacular aura about
You also may need to hit tab for the value to be set in the dashboard
Unread 05-02-2016, 12:10
FRC #4091
We got it to work! Thanks, lopsided98. That was extremely simple, but we tried so hard to figure it out. You made our lives a lot easier.
