Go to Post I think CD is worth about 3 billion in Google stock. Talk about one hell of a fundraiser! - Joe Matt [more]
Unread 04-02-2016, 20:30
1337WaffleBendr 1337WaffleBendr is offline
FRC #5489
1337WaffleBendr is an unknown quantity at this point
Wondering about GRIP
Hi we are new to vision this year, and have gotten GRIP to work for us.
We have gotten GRIP to get, process images, and give us info on network tables. We are at the point that we are ready to integrate GRIP into our code. We are just unsure of a couple of things.
1) How to start GRIP from C++ code.
2) How to get NetworkTables numbers into our code for processing.
Thanks in advance
Unread 05-02-2016, 09:14
nollchr nollchr is offline
nollchr is an unknown quantity at this point
Re: Wondering about GRIP
The GRIP Wiki is located here: https://github.com/WPIRoboticsProjects/GRIP/wiki
Unread 05-02-2016, 20:40
FRC #5489
thanks but i have been to the wiki and it is not much help. there is some code but no explanation and i don't know enough to decipher it. if someone will please explain how to do these things too me like i'm five that would be great
Unread 05-02-2016, 20:53
The sample code is spawning a separate process via the fork() function and then executing a command line that is running a separate java grip program in that process.
The other part of the code is getting a subset of the network table containing the contour report and parsing it out.
Unread 08-02-2016, 20:34
MaikeruKonare's Avatar
MaikeruKonare MaikeruKonare is offline
Programming Division Captain
AKA: Michael Conard
FRC #4237 (Team Lance-a-Bot)
MaikeruKonare is an unknown quantity at this point
This is the sample code.
#include <unistd.h>
#include <stdio.h>
#include "WPILib.h"
class MyRobot: public IterativeRobot
	std::shared_ptr<NetworkTable> grip;
    const char *JAVA = "/usr/local/frc/JRE/bin/java";
    char *GRIP_ARGS[5] = { "java", "-jar", "/home/lvuser/grip.jar", "/home/lvuser/project.grip", NULL };
public:
	MyRobot():grip(NetworkTable::GetTable("GRIP")){std::cout << "GRIP Test in Constructor" << std::endl;}
    void RobotInit() override {
    	std::cout << "GRIP Test in RobotInit" << std::endl;
        /* Run GRIP in a new process */
        int retval=fork();
        if ( retval == 0) {
        	// in the child process so start Java with the GRIP program
            if (execv(JAVA, GRIP_ARGS) == -1) {
                perror("Error running GRIP in new process");
        // in the parent process
        else if (retval == -1) printf("fork error returned to parent error %d\n", retval);
        else printf("fork okay continuing with parent robot code\n");
    void AutonomousPeriodic() override {
    	std::cout << "GRIP Test in AutonomousPeriodoc" << std::endl;
    	double init[3];init[0]=2.3; init[1]=3.4;init[2]=4.5;
    	while(true){
    		/* Get published values from GRIP using NetworkTables */
    		auto areas = grip->GetNumberArray("MyTargetTable/area", llvm::ArrayRef<double>());
    		for (auto area : areas) {
    			std::cout << "Got contour with area=" << area << std::endl;
    		auto blobsx = grip->GetNumberArray("myBlobsReport/x", init /*llvm::ArrayRef<double>()*/);
    		for (auto blob : blobsx) {
    			std::cout << "Got blob with x=" << blob << std::endl;
    		auto blobsy = grip->GetNumberArray("myBlobsReport/y", init /*llvm::ArrayRef<double>()*/);
    		for (auto blob : blobsy) {
    			std::cout << "Got blob with y=" << blob << std::endl;
    		auto blobssize = grip->GetNumberArray("myBlobsReport/size", init /*llvm::ArrayRef<double>()*/);
    		for (auto blob : blobssize) {
    			std::cout << "Got blob with size=" << blob << std::endl;
START_ROBOT_CLASS(MyRobot)
If you're still having issues, the author of Grip has an account on ChiefDelphi. He will find you eventually and give you his pro advice.
Unread 09-02-2016, 20:41
FRC #5489
Still having these problems
Unread 13-02-2016, 02:58
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Could you explain what these problems are? There's sample code for both of your questions here, but if there are any questions you have about it, I can answer them.
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
