Go to Post Adult coaches are the "rock stars" of our program, and I know on Simbotics the kids really do look up to and aspire to be a great as these coaches. - Karthik [more]
Unread 04-02-2016, 20:46
mhellebuyck mhellebuyck is offline
FRC #5222
mhellebuyck is an unknown quantity at this point
wiring RGB LED Lights
I bought this kit: RGB LED Light Strip With Arduino Controller Kit (am-3010), from andymark, and I don't have the slightest idea on how to wire it. I just want to use it this year to make our robot look "cooler". Nothing fancy. Can you send me a pic, or point me in the right direction? I have been all over the internet the last few days, and I couldn't find anything that matched what I need!!!
Thanks
Unread 04-02-2016, 20:52
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Re: wiring RGB LED Lights
We also bought these http://www.amazon.com/gp/product/B00...p age_o00_s02
and do not know how to wire/program them. It has a standard 3 pin header but that is about all I know about them.
Unread 04-02-2016, 21:48
MetaEngineer's Avatar
MetaEngineer MetaEngineer is offline
Director of magic smoke
AKA: Barden
FRC #0246
MetaEngineer is an unknown quantity at this point
On the AndyMark product page the second picture is the wiring diagram: http://www.andymark.com/product-p/am-3010.htm
- 12 volts input power and ground from the PDP go to both the Arduino and the DC-DC converter.
- Output power and ground from the DC-DC converter goes to the LED strip.
- Wire the Arduino signal ground to the ground terminal on the output side of the DC-DC converter.
- Wire the Arduino Digital IO pin to the LED strip signal wire. Make sure your code has the correct IO pin number or it won't work. The example code has it set for Pin 5.
Unread 05-02-2016, 05:56
FRC #5222
Thank you for your quick response! I will try it today!
Unread 05-02-2016, 06:20
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
That LED string uses the WS2812B individually addressable LEDs. They are also sold by Adafruit, and on their site you'll find links to more tutorials, code examples, and projects using them than one could read in a week.
You'll probably want to get somebody up to speed on Arduino programming to control the LEDs. It will be difficult to get the tight 800kHz timing they require out of the roboRIO while it's busy running the robot.
I'm an EE, but only write code when threatened and was able to get one of those strings to work.
Unread 05-02-2016, 08:11
jimbo493's Avatar
jimbo493 jimbo493 is offline
Quasi Mentor
AKA: Jimmy
FRC #3357 (The COMETS)
Team Role: Electrical
jimbo493 is on a distinguished road
You can use the same example code for the NeoPixel line at Adafruit to get these to work, and follow their guide here
FTC Student 2011-2012 FRC Student 2012-2016
FIRST Alum/Quasi-Mentor 2016-present
