Go to Post Ban the ingredients for cheesecake, and stores will find substitutes. Remove the market for them, and stores have no reason to make them. - Rachel Lim [more]
Unread 04-02-2016, 21:09
ForeverAlon ForeverAlon is offline
AKA: Alon Greyber
FRC #0900 (Zebracorns)
ForeverAlon will become famous soon enoughForeverAlon will become famous soon enough
Need help using NavX Micro with Linux on Jetson TK1
Hi Everyone,
Our team is looking to mount the NavX Micro to our onboard vision processor (the Jetson TK1) which is a Linux ARM based machine. Currently the only drivers I have found for the NavX are for Windows. Does anyone have any experience using this device with Linux or any idea how to go about implementing this. Thanks in advance.
Unread 05-02-2016, 10:14
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Need help using NavX Micro with Linux on Jetson TK1
I may be wrong, but I think the NavX (no experience with it) uses a USB-UART interface. You may be lucky and have drivers installed on the Jetson.
You can do a ls /dev/ttyUSB* to see if it shows up. You may also try a ls /dev/tty*. In my experience, they show up as a ttyUSB# device, usually 0.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 05-02-2016, 10:43
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Originally Posted by ForeverAlon View Post
Hi Everyone,
The navX-Micro has I2C and USB interfaces; not sure which interface you'd select. USB is faster, and according to this article on the web, Linux has a built-in device driver that'd work with it:
"This sample code creates a USB connected virtual COM port, using the USB CDC class (Communications Device Class.) On Linux, this class does not require a driver: it is supported directly by the kernel. Simply put, it makes the STM32F4 function similar to a USB-serial adapter."
Next, are you wanting to interface to this from C++ or Java on the TK1?
I believe your vision code is all C++.
Based upon that, my thinking is you'd USB and C++.
A place to start would be the RoboRIO C++ class sources that work w/the WPI Library. [There are Java sources that are very similar, if you choose that language instead.]
You will need to modify the "IO" module (SerialIO.cpp or RegisterIOI2C.cpp) that corresponds to either I2C or the Serial Port. And you'll need to modify the AHRS class to remove the WPI Library code that inherits from PIDSource and LiveWindowSendable.
It'll be a bit of work, but I think it's doable. James Parks on your team is familiar w/the serial protocol. And you can contact me at scott@kauailabs.com if you have any questions.
Unread 05-02-2016, 12:09
I'm curious about your vision processing architecture that makes it better to have the IMU attached to the vision processor, rather then the roboRIO. In FRC, it's most common to use the gyro to close the loop, with setpoint updates from vision processing. In that case, it's much better to have the gyro connected to the roboRIO, as you need low latency when closing the loop, but can afford higher latency on setpoint updates.
Unread 05-02-2016, 13:16
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Who says you can't have both?
