Looking for a new Photo Sensor
We are looking for a digital photo sensor. We previously had the Allen Bradley right-sight 42EF-DIMNAK-A2. Is there any way to modify it to make it a digital sensor? Or, does anyone know of a good digital photo sensor? Thanks!
Re: Looking for a new Photo Sensor
What makes you believe it isn't a digital sensor?
When testing, we were getting a range of values rather than just 1 and 0. We're working on it right now, but from what we can tell, it doesn't return boolean values in the code.
... and how are you reading it in your code? Last edited by Ether : 06-02-2016 at 12:15. |
The 42EF-DIMNAK is digital, but it is designed for operation using 10.8 to 30V, not 5V. See this thread for more details.
In a general context, however... and note that there are likely better solutions in this specific case based on what I've read above... but in a general context you can turn an analog input into a digital output by using a comparator https://en.wikipedia.org/wiki/Comparator
There are a number of cheap op-amp/comparator chips out there... you feed your analog sensor into one input on the comparator, and use a potentiometer as a voltage divider on the other input to provide a reference voltage. When your input voltage exceeds the reference voltage, your signal goes high (or low, if you want to hook it up that way). Google a bit and you'll find sites like this http://home.cogeco.ca/~rpaisley4/Comparators.html but maybe check out some of the options above before using this solution in this specific case. Jason |
#7
Megan - For a digital photo sensor, we like the DFRobot IR sensor, it is adjustable to trigger at distances from 3 to 80 cm. Runs on 5VDC for $7.50. Part number SEN0019, DFRobot.com. No affiliation.
We can give you one of ours if you like, so you can try it out. PM me or contact us through team836@robobees.org. Last edited by Richard100 : 08-02-2016 at 08:54. |
#8
AutomationDirect has lots of different kinds of photo sensors.
Use your KOP voucher to take $30 off ... AutomationDirect Sensors Make sure you order an NPN output version and that it runs on 12Vdc. |
#9
