Go to Post I wouldn't mind dropping a banana peal or throwing a red turtle shell at other robots, but that's the rules! - SpaceOsc [more]
Unread 06-02-2016, 12:34
TimTheGreat's Avatar
TimTheGreat TimTheGreat is online now
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
ChangeControlMode RobotDrive CANTalon
We have encoders hooked up to our drivetrain CANTalons and were wondering if we can do set(EncoderPosition) to make the robot go a certain distance. I haven't found a way but I may be doing it wrong.
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 06-02-2016, 13:08
Re: ChangeControlMode RobotDrive CANTalon
Look at Section 10.1 in the Talon SRX Software Reference Manual.
If you want to go a certain distance while limiting max speed and max acceleration, you might want to learn about motion profiling.
Unread 06-02-2016, 22:20
The "correct" way is to put the Talon SRX in position control mode and tell it to run to the target encoder position using its internal closed-loop programming.
The easiest way might be for your own code to read the encoder position and run the motors until it reaches the desired value.
