Go to Post While those ideals might exist in black and white perfection; in the real world, with very rare exception, they can only be implemented as compromises in shades of gray. - gblake [more]
Unread 06-02-2016, 16:19
frcStuff's Avatar
frcStuff frcStuff is offline
フォスタ--
FRC #4268 (Beehive Robotics)
frcStuff is an unknown quantity at this point
Code not deploying
Every time we try to deploy code to the roboRIO it fails. This is the error that is gives us:
Buildfile: C:\Users\Beehive Robotics\workspace\FRC2016\build.xml
Trying to override old definition of task classloader
clean:
[delete] Deleting directory C:\Users\Beehive Robotics\workspace\FRC2016\build
[delete] Deleting directory C:\Users\Beehive Robotics\workspace\FRC2016\dist
compile:
[mkdir] Created dir: C:\Users\Beehive Robotics\workspace\FRC2016\build
[echo] [athena-compile] Compiling src with classpath=C:\Users\Beehive Robotics/wpilib/java/current/lib/WPILib.jar:C:\Users\Beehive Robotics/wpilib/java/current/lib/NetworkTables.jar: to build
[javac] Compiling 5 source files to C:\Users\Beehive Robotics\workspace\FRC2016\build
jar:
[echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
[mkdir] Created dir: C:\Users\Beehive Robotics\workspace\FRC2016\dist
[mkdir] Created dir: C:\Users\Beehive Robotics\workspace\FRC2016\build\jars
[echo] [athena-jar] Copying jars from C:\Users\Beehive Robotics/wpilib/java/current/lib/WPILib.jar:C:\Users\Beehive Robotics/wpilib/java/current/lib/NetworkTables.jar: to build/jars.
[copy] Copying 2 files to C:\Users\Beehive Robotics\workspace\FRC2016\build\jars
[jar] Building jar: C:\Users\Beehive Robotics\workspace\FRC2016\dist\FRCUserProgram.jar
get-target-ip:
[echo] Trying Target: roboRIO-4268-FRC.local
[echo] roboRIO found via mDNS
dependencies:
[echo] roboRIO image version validated
[echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s...ller-java-only
[sshexec] Connecting to roboRIO-4268-FRC.local:22
[sshexec] cmd : test -d /usr/local/frc/JRE
BUILD FAILED
C:\Users\Beehive Robotics\wpilib\java\current\ant\build.xml:220: Remote command failed with exit status 1
Total time: 10 seconds
Please help. Thank you for your help.
Unread 06-02-2016, 16:30
Dan Waxman Dan Waxman is offline
FRC #0263 (Aftershock)
Rookie Year: 2016
Dan Waxman is an unknown quantity at this point
Re: Code not deploying
Did you image your rio for use with java?
Unread 06-02-2016, 16:32
frcStuff's Avatar
フォスタ--
Yeah. It was working until I was deploying some code and the computer shut off.
Unread 06-02-2016, 17:12
frcStuff's Avatar
フォスタ--
I got it to deploy. But now the comm light is red and the Driver Station can't see robot code.
Unread 08-02-2016, 12:41
mrbrenzo mrbrenzo is offline
FRC #1829
mrbrenzo is an unknown quantity at this point
We got this error when we forgot to push our JRE onto the RoboRIO after re imaging it. good luck.
