Go to Post This isn't an engineering fair and demonstration, it's FRC. Defense is part of the game. You can't expect a good FRC team to just sit there and get clobbered by a full-court shooter; they're going to engineer a solution to the problem. - Kevin Sevcik [more]
Unread 06-02-2016, 17:56
koreamaniac101's Avatar
koreamaniac101 koreamaniac101 is offline
Founder and Team Leader
AKA: Soohan Kim
FRC #5938 (Razor Steel Robotics 4-H Club)
Rookie Year: 2016
koreamaniac101 is an unknown quantity at this point
Cool Door Lock Motor Wiring
Hi, so we have a door lock motor with two wires (positive and ground, obviously). We are using it to push our motor up to our robot's intake wheels. My question is this: How can we hook this up to the arduino with only two wires? I know for motor controllers, they have a PWM cable that goes directly to the Roborio.
So, do we have to put the wires into the PDP? Or do we put them somewhere else in order to program them. No variable speed is needed, we just need on and off.
Unread 06-02-2016, 17:58
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Door Lock Motor Wiring
My guess is that you have to hook it up to a motor controller, just like CIMs. Put the voltage in one direction, and it moves one way. Put the voltage in the other direction, and it moves the other way.
Unread 06-02-2016, 22:32
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
There is no + or - to the wires on a door lock motor. Put the power to it in one polarity and it will go one way, reverse the polarity and it will go the other way.
It must be connected to a motor controller that receives it's power from the PDP and the signal controlling it must come from the RoboRio.
Unread 07-02-2016, 23:15
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
As Mr V said, the power has to come from the pd board, also, it neess to be controlled by a motor controller (as per R52) directly from the roborio (no arduino as per rule R68). However, you can wire it to any of the motor controllers or even the Spike relay (if you have one). Programmatically set the controller to full forwatd and reverse for the two directions.
