Go to Post Maybe we can start a FIRST team on Mars. - Karibou [more]
Unread 02-08-2016, 08:09 PM
snekiam snekiam is offline
FRC #3322 (Eagle Imperium)
snekiam has a spectacular aura aboutsnekiam has a spectacular aura aboutsnekiam has a spectacular aura about
Raspberry Pi OpenCV With Lifecam HD-3000
Has anyone been able to change camera parameters programmatically (such as exposure or buffer size) using the Microsoft LifeCam HD-3000? When we attempt to do this, we get an "error property not supported by device". Yet I am able to change some of these parameters from the command line. Anyone have any ideas?
Unread 02-09-2016, 02:59 AM
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Re: Raspberry Pi OpenCV With Lifecam HD-3000
What are you using to change the parameters from the command line? Are you able to successfully capture images with a tool like v4l2-ctl with those settings?
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 02-09-2016, 01:57 PM
We are using V4L2-ctl to change settings from the command line. I don't know how to capture an image with v4l2-ctl
Unread 02-10-2016, 09:26 PM
BenBernard BenBernard is offline
FRC #5687 (The Outliers)
Rookie Year: 2015
BenBernard is an unknown quantity at this point
I have been unable to set the exposure via OpenCV calls on the pi, although the same code running in Windows or MacOSX works fine.
However, I AM able to set the exposure using v4l2-ctl:
$ v4l2-ctl --set-ctrl=exposure_auto=1
$ v4l2-ctl --set-ctrl=exposure_absolute=25
Running this before launching our OpenCV-based code seems to do the trick.
YMMV
Unread 02-12-2016, 02:55 PM
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Do these changes stick through restart? I'm looking for a solution as well because even when I change the setting on the lifecam through my pc, the changes are different when I put it into the roboRIO. Also, does v4l2-ctl come pre-installed on the RIO or did you install it yourself?
Unread 02-12-2016, 04:44 PM
Rookie Year: 2015
My post was regarding raspberry pi, not the roborio--I'm not sure if v4l2-ctl is pre-installed on the roborio.
The changes do not "stick" but we've added them to the shell script that starts our vision tracking app.
