Go to Post Keep in mind that the lady Amanda has just taken a new job, moved herself to the NorthEast, and has to put up with people like Grady, Needel, the Kelsos, and Boucher. Let's give her some patience and sympathy. - Andy Baker [more]
Unread 02-09-2002, 03:50
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
Wink Battle Axe in Max
The blade: I made a profile of the blade with three splines, and then a green cross section of the blade in the middle. I then copied the cross section and changed those to fit the three splines. There's a Spline/Patch CrossSection and Surface on top. With the red splines guiding the features, it's quite easy.
The head: It's just a lathed curve with lots of cut polygons, extrusions, and vector adjustments, with a NURMS on top. I'm not skilled, and it took me about two hours.
Any tips you have?
Unread 02-09-2002, 09:30
Chris Nowak Chris Nowak is offline
Soudeska?
#0074
Chris Nowak is an unknown quantity at this point
Wow. I would have to say thats awesome. You're not skilled? Don't joke around. The only thing I could think of is that the blade looks too smooth in parts. This is extraordinarily impressive and I hope others follow in your example. You've inspired me to go work on mine some, too.
Unread 02-09-2002, 10:45
Soukup's Avatar
Soukup Soukup is offline
Animation Guru
AKA: David Soukup
Soukup is on a distinguished road
materials
what sort of materialing did you use for the head and eyes?
soukupd_gv@hotmail.com
Team 74 Alumni
2003 Great Lakes, Midwest, and West Michigan Regional Animation Award Winner
Unread 02-09-2002, 13:54
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
the eyes look like just a simple yellow, and the head looks like a raytrace with a bronze map. just a guess.
I really like how you elongated the head.
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 02-09-2002, 16:45
Post Material
The material is a modified Dark Gold metal from the material library in 3ds. If you don't have that, you can make it by using an Anisotrophic shader. Use a yellow-brown for the diffuse color, and a lighter yellow brown for the specular color. Set the specular level to a large value (depends on what you want), glossiness around 20, and anisotrophy around 50. Then apply a reflection map to the material as an environment (spherical, preferably)... use any picture with a little contrast... and it'll look like random reflections. If you use dark greys for the colors, you get chrome.
I need to make the thing attaching the blade to the shaft next...
Unread 02-09-2002, 21:43
SlamminSammy's Avatar
SlamminSammy SlamminSammy is offline
SlamminSammy is on a distinguished road
Send a message via AIM to SlamminSammy
Can .max and .3ds files be attached? If so, they could be very useful.
The opinions stated above are not necessarily those expressed by the FIRST Robotics Program, its participating teams, or any other individual or organization.
Unread 03-09-2002, 02:25
Progress
I've more or less finished the top part... it just needs the little blade in the back. Here it is:
I'm too sleepy to explain for non-3ds people... I'll do it tomorrow.
I've attached complete meshes for the head and blade as .max and .3ds. In the .max, I managed to get a file not collapsed even once, so it goes right down to the spline I stared with. The .3ds has the Meshsmooth NURMS removed.
I forgot the textures in the file below... get them here: http://suneetpics.netfirms.com/eyedot.zip
(Please excuse the large .png, I use Macromedia Fireworks)
Unread 03-09-2002, 19:03
Right... to make the blade attach-er, I spline/patched again. This time, I drew a red "Donut" shape on the gird, and used 3d-snap, snapping to edges, to draw the different splines.
The only thing you want to keep in mind is that you have to draw the different splines with the same number of verticies, and in the same "pattern", so the vertex numbers line up from layer to layer, as in the picture. I did it in three sections, and attached the sections by cutting away polygons and welding verticies by hand. You should be familiar with the CrossSection modifier, if you want to switch to MAX...
Unread 04-09-2002, 15:40
Jack's Avatar
AKA: Andrew Schenk
Suneet,
the zip folder in your last,last post dosn't contain anything. could you put up the max file?
thanks
Unread 04-09-2002, 20:25
.zip
You're right, thanks for letting me know... The forum upload did that to it, I suppose... Here's a direct link to a file: Axe Top Parts
I can't finish it during the week with school started and all.
Unread 06-09-2002, 18:07
Matt VP's Avatar
Matt VP Matt VP is offline
#0074 (Hot Heads)
Matt VP is an unknown quantity at this point
Excellent... now you just need to sharpen the blade. =o
Battle Axe - CN Chris Nowak 3D Animation and Competition 2 09-09-2002 00:39
3ds max VS Maya VS XSI DisTurbed 3D Animation and Competition 7 08-08-2002 22:52
FIRST MAX Animation Tutorials Robby O 3D Animation and Competition 2 01-02-2002 22:53
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
