Go to Post :D NASCAR is way harder than we thought. - SL8 [more]
Unread 09-02-2016, 16:15
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Java Threading Question
Question to those of you who use Threading (class MyClass extends Thread implements Runnable) for various scripting:
We wrote a Thread class that carries out a script upon button press (in our case, performing about 5 mechanical timed functions in sequence to shoot our boulder). The script itself is in our void run(){} method and gets invoked upon callout of our shooterclass.start();
The script in run() is not an infinite loop -- it would merely end and I would *think* the thread itself would terminate.
So, when the script is complete and sometime in the future I press the same button, calling out MyClass.start(); a second time throws an exception. The only way I've gotten around this was to generate a new Thread (shooterclass = new MyClass(); ) before calling out shooterclass.start(); again.
Even though this works, I'm worried I'm just creating a ton of new threads that will bog down the roboRio eventually. What is the correct way to terminate a Thread? the API says Thread.stop() is deprecated
Should I just assume the thread is always running, allowing me to specifically call out shooterclass.run() in the 2nd iteration and beyond?
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 09-02-2016, 16:45
Jared's Avatar
Jared Jared is offline
Re: Java Threading Question
What you have now (creating a new thread each time) is the right thing to do.
Your thread will stop once your run method returns, so you don't need to worry about cleaning up after it. As you've seen, you can't start it again, and you need to make a new thread.
Unread 09-02-2016, 23:52
seg9585's Avatar
AKA: Eric
Excellent, thanks for the feedback! Will keep it as is.
My FIRST legacy:
