Compiling GRIP for the Jetson TK1
Our team wants to use the TK1 to do image processing and to exeriment
with GRIP tools on it. Here's what I did to compile and run GRIP on the Jetson TK1. 1. [ flash and install the NVidia distribution ] 2. Mark the special NVidia package so that updates won't overwrite them. Code:
sudo apt-mark hold xserver-xorg-core Code:
from: http://www.oracle.com/technetwork/java/javase/downloads/jdk8-downloads-2133151.html jdk-8u65-linux-arm32-vfp-hflt.tar.gz I installed it in /usr/lib/jvm/ $ export JAVA_HOME=/usr/lib/jvm/jdk1.8.0_65 $ PATH=$PATH:$JAVA_HOME/bin Code:
git clone --depth=1 https://github.com/PeterJohnson/ntcore.git ./gradlew :arm:build -PcompilerPrefix= # ./gradlew publish -PmakeDesktop ?? $ ./gradlew -PcompilerPrefix= -PmakeDesktop :arm:build Code:
from: https://wiki.openjdk.java.net/displa...ilding+OpenJFX install deps sudo apt-get install bison flex gperf libasound2-dev libgl1-mesa-dev \ libgstreamer0.10-dev libgstreamer-plugins-base0.10-dev libjpeg-dev \ libpng-dev libx11-dev libxml2-dev libxslt1-dev libxt-dev \ libxxf86vm-dev pkg-config x11proto-core-dev \ x11proto-xf86vidmode-dev libgtk2.0-dev \ libxtst-dev libudev-dev edit /etc/apt/sources.list and uncomment universe sources sudo apt-get update sudo apt-get install mercurial libavcodec-dev libavformat-dev install gradle wget https://services.gradle.org/distribu...le-1.8-bin.zip Code:
diff --git a/build.gradle b/build.gradle
index c1d2486..843d99a 100644
--- a/build.gradle
+++ b/build.gradle
@@ -704,7 +704,7 @@ if (IS_WINDOWS && OS_ARCH != "x86" && OS_ARCH != "amd64") {
throw new Exception("Unknown and unsupported build architecture: $OS_ARCH")
} else if (IS_MAC && OS_ARCH != "x86_64") {
-} else if (IS_LINUX && OS_ARCH != "i386" && OS_ARCH != "amd64") {
+} else if (IS_LINUX && OS_ARCH != "i386" && OS_ARCH != "amd64" && OS_ARCH != "arm") {
@@ -2554,8 +2554,8 @@ project(":web") {
} else {
environment([
"QMAKESPEC" : "linux-g++-32",
- "QMAKE_CFLAGS" : "-m32",
- "QMAKE_LFLAGS" : "-m32",
+ // "QMAKE_CFLAGS" : "-m32",
+ // "QMAKE_LFLAGS" : "-m32",
} else if (t.name.startsWith("arm")) {
@@ -3260,8 +3260,8 @@ project(":apps") {
ant.properties['jfxbuild.jfxrt.jar'] = jfxrtJar
ant.properties['platforms.JDK_1.8.home'] = "${rootProject.ext.JDK_HOME}"
- ant.project.executeTarget("sampleAppsJar")
- ant.project.executeTarget("scenebuilderSampleAppsJar")
+ // ant.project.executeTarget("sampleAppsJar")
+ // ant.project.executeTarget("scenebuilderSampleAppsJar")
if (!t.name.startsWith("arm")) {
ant.project.executeTarget("scenebuilderAppJar")
diff --git a/buildSrc/linux.gradle b/buildSrc/linux.gradle
index 753d79c..34a313f 100644
--- a/buildSrc/linux.gradle
+++ b/buildSrc/linux.gradle
@@ -45,7 +45,7 @@ def commonFlags = [
"-fno-strict-aliasing"
"-fPIC", "-fno-omit-frame-pointer", // optimization flags
"-W"
"-Wall", "-Wno-unused", "-Wno-parentheses", "-Werror=implicit-function-declaration"] // warning f
-if (!IS_64) {
+if (false && !IS_64) {
commonFlags += "-m32"
@@ -173,7 +173,7 @@ LINUX.launcher.compiler = compiler
LINUX.launcher.ccFlags = ["-DJAVAARCH=\"$OS_ARCH\""
"-I$JDK_HOME/include", "-I$JDK_HOME/include/linux", "-c"]
LINUX.launcher.linker = linker
LINUX.launcher.linkFlags = ["-ldl"]
-if (!IS_64) {
LINUX.launcher.ccFlags += "-m32"
LINUX.launcher.linkFlags += "-m32"
@@ -183,7 +183,7 @@ LINUX.launcherlibrary.compiler = compiler
LINUX.launcherlibrary.ccFlags = ["-DJAVAARCH=\"$OS_ARCH\""
LINUX.launcherlibrary.linker = linker
LINUX.launcherlibrary.linkFlags = ["-ldl"
"-lpthread", "-shared"]
-if (!IS_64) {
LINUX.launcherlibrary.ccFlags += "-m32"
LINUX.launcherlibrary.linkFlags += "-m32"
gradle Code:
gradle test Code:
gradle zips Code:
Extract jar over the existing jdk build/bundles/javafx-sdk-overlay.zip contains data to overlay existing JAVA_HOME Code:
cd /usr/lib/jvm/jdk1.8.0_65 jar -xvf [...]/build/bundles/javafx-sdk-overlay.zip These packages are from the NVidia TK1 download page. Code:
sudo dpkg -i cuda-repo-l4t-r23.1-7-0-local_7.0-71_armhf.deb
sudo dpkg -i libopencv4tegra-repo_2.4.12.3_armhf_l4t-r23.deb
sudo apt-get update
sudo apt-get install cuda-toolkit-7-0 libopencv4tegra libopencv4tegra-dev
[ install pseudo packages java8 dev packages ] create file java8-jre Code:
### Commented entries have reasonable defaults. ### Uncomment to edit them. # Source: <source package name; defaults to package name> Section: java Priority: optional # Homepage: <enter URL here; no default> Standards-Version: 3.9.2 Package: java8-jre Version: 1.8 # Maintainer: Your Name <yourname@example.com> # Pre-Depends: <comma-separated list of packages> Depends: java8-jre-headless # Recommends: <comma-separated list of packages> # Suggests: <comma-separated list of packages> Provides: java-runtime, java2-runtime, java5-runtime, java6-runtime, java7-runtime # Replaces: <comma-separated list of packages> # Architecture: all # Copyright: <copyright file; defaults to GPL2> # Changelog: <changelog file; defaults to a generic changelog> # Readme: <README.Debian file; defaults to a generic one> # Extra-Files: <comma-separated list of additional files for the doc directory> # Files: <pair of space-separated paths; First is file to include, second is destination> # <more pairs, if there's more than one file to include. Notice the starting space> Description: java 8 oracle java 8 . From Java Oracle Code:
### Commented entries have reasonable defaults. ### Uncomment to edit them. # Source: <source package name; defaults to package name> Section: java Priority: optional # Homepage: <enter URL here; no default> Standards-Version: 3.9.2 Package: java8-jre Version: 1.8 # Maintainer: Your Name <yourname@example.com> # Pre-Depends: <comma-separated list of packages> Depends: java8-jre-headless # Recommends: <comma-separated list of packages> # Suggests: <comma-separated list of packages> Provides: java-runtime-headless, java2-runtime-headless, java5-runtime-headless, java6-runtime-headless, java7-runtime-headless, openjdk-7-jre-zero # Replaces: <comma-separated list of packages> # Architecture: all # Copyright: <copyright file; defaults to GPL2> # Changelog: <changelog file; defaults to a generic changelog> # Readme: <README.Debian file; defaults to a generic one> # Extra-Files: <comma-separated list of additional files for the doc directory> # Files: <pair of space-separated paths; First is file to include, second is destination> # <more pairs, if there's more than one file to include. Notice the starting space> Description: java 8 headless oracle java 8 headless . From Java Oracle support Code:
sudo apt-get install equivs equivs-build java8-jre equivs-build java8-jre-headless sudo dpkg -i java8-jre*.deb sudo apt-get update sudo apt-get install maven Code:
git clone --depth=1 https://github.com/bytedeco/javacpp.git edit src/main/resources/org/bytedeco/javacpp/properties/linux-arm.properties Code:
diff --git a/src/main/resources/org/bytedeco/javacpp/properties/linux-arm.properties b/src/main/resources/org/by index 6580495..fcd0c1c 100644 --- a/src/main/resources/org/bytedeco/javacpp/properties/linux-arm.properties +++ b/src/main/resources/org/bytedeco/javacpp/properties/linux-arm.properties @@ -5,8 +5,8 @@ platform.includepath.prefix=-I platform.includepath= platform.compiler=g++ platform.compiler.cpp11=-std=c++11 -platform.compiler.default=-march=armv5te -platform.compiler.fastfpu=-march=armv7-a -mfpu=neon -ffast-math +platform.compiler.default=-march=native +platform.compiler.fastfpu=-march=armv7-a -mfpu=neon-vfpv4 -ffast-math platform.compiler.nodeprecated=-Wno-deprecated-declarations platform.compiler.output=-Wl,-rpath,$ORIGIN/ -Wall -O3 -fPIC -shared -s -o\u0020 platform.linkpath.prefix=-L Code:
mvn install Code:
git clone --depth=1 https://github.com/bytedeco/javacpp-presets.git Code:
sudo apt-get install curl cmake Code:
diff --git a/opencv/cppbuild.sh b/opencv/cppbuild.sh
index 25a9b50..363a171 100755
--- a/opencv/cppbuild.sh
+++ b/opencv/cppbuild.sh
@@ -47,7 +47,7 @@ case $PLATFORM in
make install/strip
linux-arm)
- CC=arm-linux-gnueabi-"$OLDCC" CXX=arm-linux-gnueabi-"$OLDCXX" CMAKE_C_COMPILER=$CC CMAKE_CXX_COMPILER=$
+ CC="$OLDCC" CXX="$OLDCXX" CMAKE_C_COMPILER=$CC CMAKE_CXX_COMPILER=$CXX $CMAKE -DCMAKE_INSTALL_PREFIX=..
make -j4
make install
diff --git a/artoolkitplus/cppbuild.sh b/artoolkitplus/cppbuild.sh
index a487aae..a0be80f 100755
--- a/artoolkitplus/cppbuild.sh
+++ b/artoolkitplus/cppbuild.sh
@@ -27,6 +27,11 @@ case $PLATFORM in
make -j4
make install
+ linux-arm)
+ CC="$OLDCC" CXX="$OLDCXX" $CMAKE -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=..
+ make -j4
+ make install
linux-x86)
CC="$OLDCC -m32" CXX="$OLDCXX -m32" $CMAKE -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=..
make -j4
diff --git a/ffmpeg/cppbuild.sh b/ffmpeg/cppbuild.sh
index b8ebb10..8c8e617 100644
--- a/ffmpeg/cppbuild.sh
+++ b/ffmpeg/cppbuild.sh
@@ -28,7 +28,7 @@ else
LAME=lame-3.99.5
SPEEX=speex-1.2rc2
OPENCORE_AMR=opencore-amr-0.1.3
- OPENSSL=openssl-1.0.2e
+ OPENSSL=openssl-1.0.2f
OPENH264_VERSION=1.5.0
X265=x265_1.8
VPX_VERSION=v1.5.0
@@ -166,6 +166,44 @@ case $PLATFORM in
make install
+ linux-arm) ## host native build
+ cd $LAME
+ ./configure --prefix=$INSTALL_PATH --disable-shared --with-pic CFLAGS=""
+ make -j $MAKEJ
+ make install
+ cd ../$SPEEX
+ make -j $MAKEJ
+ make install
+ cd ../$OPENCORE_AMR
+ ./configure --prefix=$INSTALL_PATH --disable-shared --with-pic CFLAGS="" CXXFLAGS=""
+ make -j $MAKEJ
+ make install
+ cd ../$OPENSSL
+ ./Configure linux-armv4 -march=armv7-a -D__ARM_MAX_ARCH__=8 -fPIC no-shared --prefix=$INSTALL_PATH
+ make # fails with -j > 1
+ make install
+ cd ../openh264-$OPENH264_VERSION
+ make -j $MAKEJ DESTDIR=./ PREFIX=.. AR=ar ARCH=arm libraries install-static
+ cd ../$X264
+ ./configure --prefix=$INSTALL_PATH --enable-static --enable-pic --disable-opencl
+ make -j $MAKEJ
+ make install
+ cd ../$X265
+ CC="gcc" CXX="g++" $CMAKE -DENABLE_SHARED=OFF -DENABLE_PIC=ON -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTAL
+ make -j $MAKEJ
+ make install
linux-x86)
cd $LAME
./configure --prefix=$INSTALL_PATH --disable-shared --with-pic --host=i686-linux CFLAGS="-m32 -msse2"
diff --git a/flandmark/cppbuild.sh b/flandmark/cppbuild.sh
index 3f32ef7..d0fd1cd 100755
--- a/flandmark/cppbuild.sh
+++ b/flandmark/cppbuild.sh
@@ -32,6 +32,12 @@ case $PLATFORM in
cp libflandmark/*.h ../include
cp libflandmark/*.a ../lib
+ linux-arm)
+ CC="$OLDCC" CXX="$OLDCXX" $CMAKE -DCMAKE_BUILD_TYPE=Release -DOpenCV_DIR=$OPENCV_PATH/share/OpenCV/
+ make -j4 flandmark_static
+ cp libflandmark/*.h ../include
+ cp libflandmark/*.a ../lib
linux-x86)
CC="$OLDCC -m32" CXX="$OLDCXX -m32" $CMAKE -DCMAKE_BUILD_TYPE=Release -DOpenCV_DIR=$OPENCV_PATH/share/O
diff --git a/libdc1394/cppbuild.sh b/libdc1394/cppbuild.sh
index c63118d..2e39444 100755
--- a/libdc1394/cppbuild.sh
+++ b/libdc1394/cppbuild.sh
@@ -17,6 +17,11 @@ tar -xzvf ../libdc1394-$LIBDC1394_VERSION.tar.gz
cd libdc1394-$LIBDC1394_VERSION
case $PLATFORM in
+ linux-arm)
+ CC="$OLDCC" ./configure --prefix=$INSTALL_PATH
+ make -j4
+ make install-strip
linux-x86)
CC="$OLDCC -m32" ./configure --prefix=$INSTALL_PATH
make -j4
diff --git a/libfreenect/cppbuild.sh b/libfreenect/cppbuild.sh
index 57bbf90..2aeb7aa 100755
--- a/libfreenect/cppbuild.sh
+++ b/libfreenect/cppbuild.sh
@@ -27,6 +27,11 @@ fi
cd libfreenect-$LIBFREENECT_VERSION
case $PLATFORM in
+ linux-arm)
+ CC="$OLDCC" CXX="$OLDCXX" $CMAKE -DCMAKE_BUILD_TYPE=Release -DBUILD_EXAMPLES=OFF -DBUILD_FAKENECT=OFF -
+ make -j4
+ make install
linux-x86)
CC="$OLDCC -m32" CXX="$OLDCXX -m32" $CMAKE -DCMAKE_BUILD_TYPE=Release -DBUILD_EXAMPLES=OFF -DBUILD_FAKE
make -j4
# -march=native?? -mtune=cortex-a15 -march=armv7-a -mfpu=neon-vfpv4 mvn -Dplatform.compiler.default="" install --projects .,opencv,videoinput,ffmpeg,flycapture,libdc1394,libfreenect,artoolkitplus,flandmark ln ~/.m2/repository/org/bytedeco/javacpp-presets/opencv/3.1.0-1.2-SNAPSHOT/opencv-3.1.0-1.2-SNAPSHOT-linux-arm.jar ~/.m2/repository/org/bytedeco/javacpp-presets/opencv/3.1.0-1.2-SNAPSHOT/opencv-3.1.0-1.2-SNAPSHOT-linux-arm_32.jar ln ~/.m2/repository/org/bytedeco/javacpp-presets/videoinput/0.200-1.2-SNAPSHOT/videoinput-0.200-1.2-SNAPSHOT-linux-arm.jar ~/.m2/repository/org/bytedeco/javacpp-presets/videoinput/0.200-1.2-SNAPSHOT/videoinput-0.200-1.2-SNAPSHOT-linux-arm_32.jar Code:
from: http://jogamp.org/jogl/doc/HowToBuild.html This next step is important. from: http://forum.jogamp.org/env-TARGET-P...td4033904.html Code:
export TARGET_PLATFORM_ROOT=/ mkdir jogamp cd jogamp git clone --recursive --depth=1 https://github.com/sgothel/gluegen.git git clone --recursive --depth=1 https://github.com/sgothel/jogl.git Code:
cd gluegen for: https://jogamp.org/bugzilla/show_bug.cgi?id=1190 Apply patch Code:
diff --git a/make/gluegen-cpptasks-base.xml b/make/gluegen-cpptasks-base.xml
index 01d6146..766022c 100755
--- a/make/gluegen-cpptasks-base.xml
+++ b/make/gluegen-cpptasks-base.xml
@@ -1239,7 +1239,6 @@
for official JogAmp builds! -->
<linker id="linker.cfg.linux.armv6" name="${gcc.compat.compiler}">
<linkerarg value="-fpic" />
- <linkerarg value="-nostdlib" />
<linkerarg value="-Bdynamic" />
<linkerarg value="-static-libgcc" if="isGCC"/>
<linkerarg value="-static-libstdc++" if="isGCC"/>
diff --git a/make/build.xml b/make/build.xml
index d7abcd8..c69b578 100644
--- a/make/build.xml
+++ b/make/build.xml
@@ -1221,7 +1221,7 @@
<param name="description" value="GlueGen - JNI Glue Code Generator"/>
</antcall>
<antcall target="maven.${mvn.task}.artifact" inheritall="true">
- <param name="artifactId" value="gluegen-rt"/>
+ <param name="artifactId" value="gluegen-rt-main"/>
<param name="description" value="GlueGen runtime"/>
</antcall>
<antcall target="maven.${mvn.task}.native.artifact" inheritall="true">
cd make ant ant maven.install Code:
cd ../../jogl/make ant > https://gist.github.com/tysonmalchow/1624599 Code:
mvn install:install-file -Dversion=$VERSION -DlocalRepositoryPath="$MVN_REPO" -DgroupId=com.jogamp.jogl -DartifactId=jogl-all -Dpackaging=jar -Dfile="$TEMPFILE/jogl.all.jar" -DgeneratePom=true mvn install:install-file -DlocalRepositoryPath="$MVN_REPO" -Dclassifier="$platform" -Dversion=$VERSION -DgroupId=com.jogamp.jogl -DartifactId=jogl-natives -Dpackaging=jar -Dfile="$TEMPFILE/jogl-all-natives-$platform.jar" -DgeneratePom=true Code:
cd ../build mvn install:install-file -Dversion=2.4 -DlocalRepository=~/.m2/repository -DgroupId=org.jogamp.jogl -DartifactId=jogl-all-main -Dpackaging=jar -Dfile="$PWD/jar/*" -DgeneratePom=true mvn install:install-file -DlocalRepositoryPath=~/.m2/repository -Dclassifier="arm" -Dversion=2.4 -DgroupId=org.jogamp.jogl -DartifactId=jogl-natives -Dpackaging=jar -Dfile="$PWD/lib/*" -DgeneratePom=true cp gluegen-rt.jar /home/ubuntu/.m2/repository/org/jogamp/gluegen/gluegen-rt-main/2.4/gluegen-rt-main-2.4.jar cp jocl.jar /home/ubuntu/.m2/repository/org/jogamp/jocl/jocl-main/2.4/jocl-main-2.4.jar cp jogl-all.jar /home/ubuntu/.m2/repository/org/jogamp/jogl/jogl-all-main/2.4/jogl-all-main-2.4.jar Code:
cd ../../jocl /home/ubuntu/src/jogamp/jocl/src/com/jogamp/opencl/llb/impl/CLDynamicLibraryBundleInfo.java:44: error: CLDynamicLibraryBundleInfo is not abstract and does not override abstract method searchToolLibSystemPathFirst() in DynamicLibraryBundleInfo apply patch Code:
diff --git a/src/com/jogamp/opencl/llb/impl/CLDynamicLibraryBundleInfo.java b/src/com/jogamp/opencl/llb/impl/CLD
index 4f3e682..9ac026b 100644
--- a/src/com/jogamp/opencl/llb/impl/CLDynamicLibraryBundleInfo.java
+++ b/src/com/jogamp/opencl/llb/impl/CLDynamicLibraryBundleInfo.java
@@ -157,6 +157,16 @@ public final class CLDynamicLibraryBundleInfo implements DynamicLibraryBundleInf
public final RunnableExecutor getLibLoaderExecutor() {
return DynamicLibraryBundle.getDefaultRunnableExecutor();
+ @Override
+ public final boolean searchToolLibInSystemPath() {
+ return true;
+ @Override
+ public final boolean searchToolLibSystemPathFirst() {
+ return true;
cd ../build mvn install:install-file -Dversion=2.4 -DlocalRepository=~/.m2/repository -DgroupId=org.jogamp.jocl -DartifactId=jocl-main -Dpackaging=jar -Dfile="$PWD/jar/*" -DgeneratePom=true 10. install and build org.bytedeco.javacv Code:
git clone --depth=1 https://github.com/bytedeco/javacv.git Code:
diff --git a/pom.xml b/pom.xml
index 00e10f0..792e503 100644
--- a/pom.xml
+++ b/pom.xml
@@ -92,7 +92,7 @@
<dependency>
<groupId>org.bytedeco.javacpp-presets</groupId>
<artifactId>ffmpeg</artifactId>
- <version>2.8.4-${javacpp.version}</version>
+ <version>2.8.5-${javacpp.version}</version>
</dependency>
<dependency>
@@ -141,19 +141,19 @@
<dependency>
<groupId>org.jogamp.gluegen</groupId>
<artifactId>gluegen-rt-main</artifactId>
- <version>2.3.1</version>
+ <version>2.4</version>
<optional>true</optional>
</dependency>
<dependency>
<groupId>org.jogamp.jogl</groupId>
<artifactId>jogl-all-main</artifactId>
</dependency>
<dependency>
<groupId>org.jogamp.jocl</groupId>
<artifactId>jocl-main</artifactId>
</dependency>
mvn -Pmarkers,ffmpeg,dc1394,flycapture,openkinect,videoinput,jogamp install apply patch Code:
index 01b152a..f485f7d 100644
--- a/build.gradle
+++ b/build.gradle
@@ -115,6 +115,9 @@ project(":core") {
repositories {
flatDir {
dirs 'libs'
+ maven {
+ url="file:///home/ubuntu/.m2/repository"
maven {
url = "http://first.wpi.edu/FRC/roborio/maven/development"
@@ -122,11 +125,11 @@ project(":core") {
dependencies {
- compile group: 'org.bytedeco', name: 'javacv', version: '1.1'
- compile group: 'org.bytedeco.javacpp-presets', name: 'opencv', version: '3.0.0-1.1'
- compile group: 'org.bytedeco.javacpp-presets', name: 'opencv', version: '3.0.0-1.1', classifier: os
+ compile group: 'org.bytedeco', name: 'javacv', version: '1.2-SNAPSHOT'
+ compile group: 'org.bytedeco.javacpp-presets', name: 'opencv', version: '3.1.0-1.2-SNAPSHOT'
+ compile group: 'org.bytedeco.javacpp-presets', name: 'opencv', version: '3.1.0-1.2-SNAPSHOT', classifie
compile group: 'org.bytedeco.javacpp-presets', name: 'opencv-3.0.0-1.1', classifier: 'linux-frc'
- compile group: 'org.bytedeco.javacpp-presets', name: 'videoinput', version: '0.200-1.1', classifier: os
+ compile group: 'org.bytedeco.javacpp-presets', name: 'videoinput', version: '0.200-1.2-SNAPSHOT', class
compile group: 'org.python', name: 'jython', version: '2.7.0'
compile group: 'com.thoughtworks.xstream', name: 'xstream', version: '1.4.8'
compile group: 'org.apache.commons', name: 'commons-lang3', version: '3.4'
./gradlew jar build/libs/GRIP-1.1.1-37-g39f1158.jar |
Re: Compiling GRIP for the Jetson TK1
Whille step 11 builds all the classes, the jar created is empty.
I'm working on a solution. It looks like './gradlew shadowJar' should build a distributed product, but it is generating an error. There isn't any documentation from the programmer how they package this. :- ) |
To run grip, create a common location for the install.
I chose ~/lib. Run the following commands (once). Code:
ln /home/ubuntu/.gradle/caches/modules-2/files-2.1/org.controlsfx/controlsfx/8.40.10/fe12544570095b334d45c61e8c9a26f30ffc1675/controlsfx-8.40.10.jar controlsfx-8.40.10.jar ln /home/ubuntu/src/ntcore/arm/build/binaries/ntcoreSharedLibrary/libntcore.so libntcore.so ln /home/ubuntu/src/ntcore/arm/build/libs/ntcore-arm.jar ntcore-arm.jar curl -o net.schmizz.sshj-0.8.1.jar http://search.maven.org/remotecontent?filepath=org/apache/stratos/net.schmizz.sshj/0.8.1/net.schmizz.sshj-0.8.1.jar Code:
CP="-cp $HOME/lib/core-1.1.1-37-g39f1158-all.jar"
CP="$CP:$HOME/lib/ui-1.1.1.jar"
CP="$CP:$HOME/lib/controlsfx-8.40.10.jar"
CP="$CP:$HOME/lib/net.schmizz.sshj-0.8.1.jar"
java -XX:-OmitStackTraceInFastThrow -Dfile.encoding=UTF-8 -Duser.country=US -Duser.language=en -Duser.variant -ea \
$CP -Djava.library.path=$HOME/lib edu.wpi.grip.ui.Main
chmod +x run-grip |
