Hi, we are trying install Java onto the RoboRio to use GRIP, but the java-installer fails after downloading the JRE, with the error message "Unexpected end of ZLIB input stream". Our Eclipse Plugin is up to date. The following is the log file. We tried multiple times, but logs on the bottom should be the last attempt.
10/Feb/2016 16:25:50,856- ControllerFactory: Loading controller WELCOME_CONTROLLER
10/Feb/2016 16:26:09,667- AbstractController: Moving to controller INTERNET_CONTROLLER
10/Feb/2016 16:26:09,667- ControllerFactory: Loading controller INTERNET_CONTROLLER
10/Feb/2016 16:26:09,788- InternetController: No valid JRE found
10/Feb/2016 16:26:11,782- InternetController: Starting internet check
10/Feb/2016 16:26:12,038- InternetController: Internet check successful, moving to download
10/Feb/2016 16:26:12,039- AbstractController: Moving to controller DOWNLOAD_CONTROLLER
10/Feb/2016 16:26:12,040- ControllerFactory: Loading controller DOWNLOAD_CONTROLLER
10/Feb/2016 16:26:17,231- DownloadController: Loading download page page
10/Feb/2016 16:26:17,233- DownloadController: Loading download page page
10/Feb/2016 16:26:32,827- DownloadController: Loading download page page
10/Feb/2016 16:26:41,877- DownloadController: Loading unknown page
10/Feb/2016 16:26:41,878- DownloadController: Loading unknown page
10/Feb/2016 16:26:47,925- DownloadController: Loading unknown page
10/Feb/2016 16:26:47,986- DownloadController: Loading login page
10/Feb/2016 16:26:47,987- DownloadController: Loading login page
10/Feb/2016 16:26:49,417- DownloadController: Loading login page
10/Feb/2016 16:27:39,471- DownloadController: Loading unknown page
10/Feb/2016 16:27:39,472- DownloadController: Loading unknown page
10/Feb/2016 16:27:40,066- DownloadController: Signed in and have the .tar.gz link.
10/Feb/2016 16:27:40,083- AbstractController: Moving to controller DOWNLOAD_PROGRESS_CONTROLLER
10/Feb/2016 16:27:40,083- ControllerFactory: Loading controller DOWNLOAD_PROGRESS_CONTROLLER
10/Feb/2016 16:27:40,209- DownloadProgressController: Initial url is https://edelivery.oracle.com/akam/otn/java/ejdk/8u6-b23/ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz
10/Feb/2016 16:27:40,344- DownloadProgressController: Redirecting to http://download.oracle.com/otn/java/ejdk/8u6-b23/ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz?AuthParam=1455139655_9230c0969a42ffcb1a6a686850fe9192
10/Feb/2016 16:27:40,794- DownloadProgressController: Final url is http://download.oracle.com/otn/java/ejdk/8u6-b23/ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz?AuthParam=1455139655_9230c0969a42ffcb1a6a686850fe9192
10/Feb/2016 16:27:40,796- DownloadProgressController: Starting JRE Creator download. File size is 121568917 bytes
10/Feb/2016 16:27:40,817- DownloadController: Loading unknown page
10/Feb/2016 16:27:56,119- DownloadProgressController: Downloaded JRE
10/Feb/2016 16:27:56,123- AbstractController: Moving to controller UNTAR_CONTROLLER
10/Feb/2016 16:27:56,124- ControllerFactory: Loading controller UNTAR_CONTROLLER
10/Feb/2016 16:27:56,772- UntarController: Starting decompress of file C:\Users\robot\wpilib\tools\.\ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz to C:\Users\robot\wpilib\tools\.
10/Feb/2016 16:27:58,111- UntarController: Couldn't untar entry ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/rt.jar
java.io.EOFException: Unexpected end of ZLIB input stream
at java.util.zip.InflaterInputStream.fill(Unknown Source) ~[?:1.8.0_73]
at java.util.zip.InflaterInputStream.read(Unknown Source) ~[?:1.8.0_73]
at java.util.zip.GZIPInputStream.read(Unknown Source) ~[?:1.8.0_73]
at org.apache.commons.compress.archivers.tar.TarArchiveInputStream.read(TarArchiveInputStream.java:610) ~[java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.controllers.UntarController.untarJRECreator(UntarController.java:86) ~[java-installer.jar:?]
at java.lang.Thread.run(Unknown Source) [?:1.8.0_73]
10/Feb/2016 16:27:58,963- UntarController: Exception when untarring the JRE
at java.util.zip.InflaterInputStream.skip(Unknown Source) ~[?:1.8.0_73]
at org.apache.commons.compress.archivers.tar.TarArchiveInputStream.skip(TarArchiveInputStream.java:207) ~[java-installer.jar:?]
at org.apache.commons.compress.utils.IOUtils.skip(IOUtils.java:101) ~[java-installer.jar:?]
at org.apache.commons.compress.archivers.tar.TarArchiveInputStream.getNextTarEntry(TarArchiveInputStream.java:259) ~[java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.controllers.UntarController.untarJRECreator(UntarController.java:99) ~[java-installer.jar:?]
10/Feb/2016 16:28:34,553- DesktopApi: Trying to exec:
cmd = explorer
args = %s
%s = .
10/Feb/2016 16:28:34,586- DesktopApi: Process is running.
10/Feb/2016 16:28:43,764- ErrorController: Exiting from error screen
10/Feb/2016 16:29:45,061- ControllerFactory: Loading controller WELCOME_CONTROLLER
10/Feb/2016 16:32:39,360- AbstractController: Moving to controller INTERNET_CONTROLLER
10/Feb/2016 16:32:39,360- ControllerFactory: Loading controller INTERNET_CONTROLLER
10/Feb/2016 16:32:39,427- MainApp: Found JRE, checking hash
10/Feb/2016 16:32:39,747- MainApp: Computed hash is 329E1B1EEC88756E81D8C5D57A0C461B, official hash is 082F08397B0D3F63844AB472B5111C8C
10/Feb/2016 16:32:39,749- InternetController: No valid JRE found
10/Feb/2016 16:32:40,740- InternetController: Starting internet check
10/Feb/2016 16:32:41,542- InternetController: Internet check successful, moving to download
10/Feb/2016 16:32:41,545- AbstractController: Moving to controller DOWNLOAD_CONTROLLER
10/Feb/2016 16:32:41,546- ControllerFactory: Loading controller DOWNLOAD_CONTROLLER
10/Feb/2016 16:32:42,044- DownloadController: Loading download page page
10/Feb/2016 16:32:42,045- DownloadController: Loading download page page
10/Feb/2016 16:32:44,950- DownloadController: Loading download page page
10/Feb/2016 16:32:54,634- DownloadController: Loading unknown page
10/Feb/2016 16:32:54,635- DownloadController: Loading unknown page
10/Feb/2016 16:32:57,527- DownloadController: Loading unknown page
10/Feb/2016 16:32:57,562- DownloadController: Loading login page
10/Feb/2016 16:32:57,563- DownloadController: Loading login page
10/Feb/2016 16:32:59,435- DownloadController: Loading login page
10/Feb/2016 16:33:08,731- DownloadController: Loading unknown page
10/Feb/2016 16:33:09,315- DownloadController: Signed in and have the .tar.gz link.
10/Feb/2016 16:33:09,318- AbstractController: Moving to controller DOWNLOAD_PROGRESS_CONTROLLER
10/Feb/2016 16:33:09,321- ControllerFactory: Loading controller DOWNLOAD_PROGRESS_CONTROLLER
10/Feb/2016 16:33:09,454- DownloadProgressController: Initial url is https://edelivery.oracle.com/akam/otn/java/ejdk/8u6-b23/ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz
10/Feb/2016 16:33:09,551- DownloadProgressController: Redirecting to http://download.oracle.com/otn/java/ejdk/8u6-b23/ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz?AuthParam=1455139984_c59303596287ab5d0fe3d445b8fd8c35
10/Feb/2016 16:33:10,117- DownloadController: Loading unknown page
10/Feb/2016 16:33:10,178- DownloadProgressController: Final url is http://download.oracle.com/otn/java/ejdk/8u6-b23/ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz?AuthParam=1455139984_c59303596287ab5d0fe3d445b8fd8c35
10/Feb/2016 16:33:10,182- DownloadProgressController: Starting JRE Creator download. File size is 121568917 bytes
10/Feb/2016 16:35:14,051- DownloadProgressController: Downloaded JRE
10/Feb/2016 16:35:14,058- AbstractController: Moving to controller UNTAR_CONTROLLER
10/Feb/2016 16:35:14,059- ControllerFactory: Loading controller UNTAR_CONTROLLER
10/Feb/2016 16:35:14,239- UntarController: Starting decompress of file C:\Users\robot\wpilib\tools\.\ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz to C:\Users\robot\wpilib\tools\.
10/Feb/2016 16:35:19,348- UntarController: Couldn't untar entry ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/rt.jar
10/Feb/2016 16:35:21,748- UntarController: Exception when untarring the JRE
10/Feb/2016 16:37:25,596- ControllerFactory: Loading controller WELCOME_CONTROLLER
10/Feb/2016 16:37:31,086- ErrorController: Exiting from error screen
10/Feb/2016 16:37:38,537- MainApp: Exiting installer from popup
10/Feb/2016 16:37:50,649- ControllerFactory: Loading controller WELCOME_CONTROLLER
10/Feb/2016 16:37:54,237- AbstractController: Moving to controller INTERNET_CONTROLLER
10/Feb/2016 16:37:54,238- ControllerFactory: Loading controller INTERNET_CONTROLLER
10/Feb/2016 16:37:54,340- MainApp: Found JRE, checking hash
10/Feb/2016 16:37:55,456- MainApp: Computed hash is 0409F51471679182A00EDE145DB8465E, official hash is 082F08397B0D3F63844AB472B5111C8C
10/Feb/2016 16:37:55,458- InternetController: No valid JRE found
10/Feb/2016 16:37:57,840- InternetController: Starting internet check
10/Feb/2016 16:37:58,096- InternetController: Internet check successful, moving to download
10/Feb/2016 16:37:58,098- AbstractController: Moving to controller DOWNLOAD_CONTROLLER
10/Feb/2016 16:37:58,099- ControllerFactory: Loading controller DOWNLOAD_CONTROLLER
10/Feb/2016 16:37:58,658- DownloadController: Loading download page page
10/Feb/2016 16:37:58,659- DownloadController: Loading download page page
10/Feb/2016 16:38:01,048- DownloadController: Loading download page page
10/Feb/2016 16:38:36,053- DownloadController: Loading unknown page
10/Feb/2016 16:38:36,054- DownloadController: Loading unknown page
10/Feb/2016 16:38:38,202- DownloadController: Loading unknown page
10/Feb/2016 16:38:38,231- DownloadController: Loading login page
10/Feb/2016 16:38:38,232- DownloadController: Loading login page
10/Feb/2016 16:38:39,724- DownloadController: Loading login page
10/Feb/2016 16:38:51,709- DownloadController: Loading unknown page
10/Feb/2016 16:38:51,710- DownloadController: Loading unknown page
10/Feb/2016 16:38:52,303- DownloadController: Signed in and have the .tar.gz link.
10/Feb/2016 16:38:52,305- AbstractController: Moving to controller DOWNLOAD_PROGRESS_CONTROLLER
10/Feb/2016 16:38:52,306- ControllerFactory: Loading controller DOWNLOAD_PROGRESS_CONTROLLER
10/Feb/2016 16:38:52,413- DownloadProgressController: Initial url is https://edelivery.oracle.com/akam/otn/java/ejdk/8u6-b23/ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz
10/Feb/2016 16:38:52,500- DownloadController: Loading unknown page
10/Feb/2016 16:38:52,552- DownloadProgressController: Redirecting to http://download.oracle.com/otn/java/ejdk/8u6-b23/ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz?AuthParam=1455140327_3ea2718d4ba13aa87890e2f262ffdaeb
10/Feb/2016 16:38:52,574- DownloadProgressController: Final url is http://download.oracle.com/otn/java/ejdk/8u6-b23/ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz?AuthParam=1455140327_3ea2718d4ba13aa87890e2f262ffdaeb
10/Feb/2016 16:38:52,601- DownloadProgressController: Starting JRE Creator download. File size is 121568917 bytes
10/Feb/2016 16:38:56,380- DownloadProgressController: Downloaded JRE
10/Feb/2016 16:38:56,394- AbstractController: Moving to controller UNTAR_CONTROLLER
10/Feb/2016 16:38:56,394- ControllerFactory: Loading controller UNTAR_CONTROLLER
10/Feb/2016 16:38:56,463- UntarController: Starting decompress of file C:\Users\robot\wpilib\tools\.\ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz to C:\Users\robot\wpilib\tools\.
10/Feb/2016 16:38:56,564- UntarController: Couldn't untar entry ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/charsets.jar
10/Feb/2016 16:38:56,571- UntarController: Exception when untarring the JRE
10/Feb/2016 16:44:22,957- ErrorController: Exiting from error screen
10/Feb/2016 16:44:39,354- ControllerFactory: Loading controller WELCOME_CONTROLLER
10/Feb/2016 16:44:44,073- AbstractController: Moving to controller INTERNET_CONTROLLER
10/Feb/2016 16:44:44,074- ControllerFactory: Loading controller INTERNET_CONTROLLER
10/Feb/2016 16:44:44,131- MainApp: Found JRE, checking hash
10/Feb/2016 16:44:44,228- MainApp: Computed hash is CA85126B04BFD932E7C8CB095DAAB504, official hash is 082F08397B0D3F63844AB472B5111C8C
10/Feb/2016 16:44:44,229- InternetController: No valid JRE found
10/Feb/2016 16:44:52,173- InternetController: Showing choose JRE picker
10/Feb/2016 16:45:07,795- MainApp: Found JRE, checking hash
10/Feb/2016 16:45:07,839- MainApp: Computed hash is CA85126B04BFD932E7C8CB095DAAB504, official hash is 082F08397B0D3F63844AB472B5111C8C
10/Feb/2016 16:45:07,840- InternetController: No valid JRE found
10/Feb/2016 16:45:32,327- InternetController: Starting internet check
10/Feb/2016 16:45:32,419- InternetController: Internet check successful, moving to download
10/Feb/2016 16:45:32,420- AbstractController: Moving to controller DOWNLOAD_CONTROLLER
10/Feb/2016 16:45:32,420- ControllerFactory: Loading controller DOWNLOAD_CONTROLLER
10/Feb/2016 16:45:32,558- DownloadController: Loading download page page
10/Feb/2016 16:45:32,559- DownloadController: Loading download page page
10/Feb/2016 16:45:34,529- DownloadController: Loading download page page
10/Feb/2016 16:46:13,255- DownloadController: Loading unknown page
10/Feb/2016 16:46:13,257- DownloadController: Loading unknown page
10/Feb/2016 16:46:16,575- DownloadController: Loading unknown page
10/Feb/2016 16:46:16,619- DownloadController: Loading login page
10/Feb/2016 16:46:16,620- DownloadController: Loading login page
10/Feb/2016 16:46:17,676- DownloadController: Loading login page
10/Feb/2016 16:46:28,300- DownloadController: Loading unknown page
10/Feb/2016 16:46:28,931- DownloadController: Signed in and have the .tar.gz link.
10/Feb/2016 16:46:28,934- AbstractController: Moving to controller DOWNLOAD_PROGRESS_CONTROLLER
10/Feb/2016 16:46:28,934- ControllerFactory: Loading controller DOWNLOAD_PROGRESS_CONTROLLER
10/Feb/2016 16:46:29,046- DownloadProgressController: Initial url is https://edelivery.oracle.com/akam/otn/java/ejdk/8u6-b23/ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz
10/Feb/2016 16:46:29,109- DownloadController: Loading unknown page
10/Feb/2016 16:46:29,177- DownloadProgressController: Redirecting to http://download.oracle.com/otn/java/ejdk/8u6-b23/ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz?AuthParam=1455140783_ce2299866890bbf2675b05a2d0d4e1f0
10/Feb/2016 16:46:29,200- DownloadProgressController: Final url is http://download.oracle.com/otn/java/ejdk/8u6-b23/ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz?AuthParam=1455140783_ce2299866890bbf2675b05a2d0d4e1f0
10/Feb/2016 16:46:29,203- DownloadProgressController: Starting JRE Creator download. File size is 121568917 bytes
10/Feb/2016 16:46:53,989- DownloadProgressController: Downloaded JRE
10/Feb/2016 16:46:54,000- AbstractController: Moving to controller UNTAR_CONTROLLER
10/Feb/2016 16:46:54,001- ControllerFactory: Loading controller UNTAR_CONTROLLER
10/Feb/2016 16:46:54,050- UntarController: Starting decompress of file C:\Users\robot\wpilib\tools\.\ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz to C:\Users\robot\wpilib\tools\.
10/Feb/2016 16:46:54,374- UntarController: Couldn't untar entry ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/rt.jar
10/Feb/2016 16:46:54,384- UntarController: Exception when untarring the JRE
