Go to Post Every team should have a rule about not shouting "ROBOT!" when transporting a robot around the pits/arena. - frasnow [more]
Unread 10-02-2016, 20:08
Kevin Pai's Avatar
Kevin Pai Kevin Pai is offline
FRC #5964 (Praetorians)
Rookie Year: 2015
Kevin Pai is an unknown quantity at this point
Adjusting Joystick Sensivity in Java
Its ya boy Kevin Pai coming at you, I was wondering how to adjust the sensitivity of the joystick to slow down its acceleration.
Unread 10-02-2016, 20:16
Re: Adjusting Joystick Sensivity in Java
It's unclear what you want.
Do you want the motor voltage to ramp up at a limited rate when you make large changes in command?
Or do you simply want to limit the maximum command that the joysticks can issue?
Unread 10-02-2016, 20:36
Kevin Pai's Avatar
Rookie Year: 2015
Yeah sorry for being unclear, I want to to be able to moderate the speed of a motor by changing voltage based on joystick movement. We have to be able to move the robot with slower acceleration because our joystick is too sensitive.
Unread 10-02-2016, 20:57
Does this help?
http://www.chiefdelphi.com/media/papers/2421
