Go to Post My experience in FIRST has taught me that, whatever you do, make sure that no single failure can eliminate half your drive system.[...] The worst feeling in the world is having your robot driving around in circles when there is critical business to be done on the playing field. - Andrew [more]
View Poll Results: Which defenses are proving to be nastier than you initially thought?
Low Bar 15 8.57%
Portcullis 12 6.86%
Sally Port 19 10.86%
Cheval De Frise 19 10.86%
Rock Wall 10 5.71%
Rough Terrain 16 9.14%
Drawbridge 15 8.57%
Ramparts 56 32.00%
Moat 80 45.71%
Multiple Choice Poll. Voters: 175. You may not vote on this poll
Unread 12-02-2016, 11:53
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
Gotcha! That defense was nastier than I thought...
Earlier this week, while we were running tests with our robot, we unexpectedly had some issues going over the rough terrain... We had previously just been driving quickly over it and had no issues. However, we realized that there are going to be times when we find ourselves moving over defenses more slowly, so we were running some tests - and found that, about 20% of the time, we got into a nasty "tortuga." Thankfully, we were able to make some minor adjustments to the skid plate and weight distribution to overcome the problem. (We were really worried, we'd have to move the bottom of the robot up 2" - which would be brutal as we are designed to go under the low bar and space is already really tight....) Still, that defense definitely proved nastier than we had expected. Anybody else have similar experiences?
Unread 12-02-2016, 12:02
Trevor1523's Avatar
Trevor1523 Trevor1523 is offline
Meme Queen
FRC #1523 (MARS / 6685 RPBHSR)
Trevor1523 is an unknown quantity at this point
Re: Gotcha! That defense was nastier than I thought...
For me, the number one thing would have to be the Ramparts. It was very surprising to see what happened to our robot in testing.
Another one is the Rock Wall, but I think we all knew that would be difficult to surpass.
2015 Orlando Regional Finalists
FRC Team 1523 [2014-xxxx]
FRC Team 6685 [2017]
bogally99 bogally99 is offline
FRC #0159
bogally99 is an unknown quantity at this point
A lot of the problems we had with them was that they busted our chains. We weren't expecting them to be able to actually smash back against us so hard that our chains popped.
Unread 12-02-2016, 12:03
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
When we went and did drive testing over defenses at a practice facility, we were only able to go over the rough terrain consistently, and we could clear the moat probably 25% of the time. However, the Rock Wall and the Ramparts were too high for our drivetrain, even when going Dukes of Hazzard style crossing, so we are currently modifying our drivetrain to make it easier. But after this change, we should be good.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 12-02-2016, 12:08
FRC #0159
We had the exact same problems. We have modified our drive train to articulate on one side, and removed the front and rear frame members. How did you modify your drive train to deal with this?
Unread 12-02-2016, 12:25
So, at the moment, we have a VersaFrame style chassis with a front brace, which is being removed, and we will be replacing our drive frame 2x1 stocks, but making them one inch longer and have a cut that is angled inwards, with the front wheels moved forward so they stick out into the 'wedge' cut.
Its kind of hard to describe, and we haven't finished it yet, so here's a bad MSPaint drawing of the changes (wheels will stay on the same side of the frame, but I drew it that way so it would be evident what cut we were making)
http://imgur.com/DdmtWRO
Unread 12-02-2016, 12:33
RoboChair's Avatar
AKA: Devin Castellucci
Driving over the Rock Wall with our 6 inch wheels has been actually rather pleasant. The Moat and Ramparts are not as easy as most seem to think they will be.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 12-02-2016, 12:47
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
Although we where still able to cross it, the moat has caused the most problems for 1065. We had a piece of channel on the rear of our robot that consistantly got hung up if we tried to cross slowly. In addition to removing it we found hitting the moat and ramparts at full speed the best way to prevent getting stuck.
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
Unread 12-02-2016, 13:03
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Ramparts I get, but how much more difficult is the real-field moat from the aluminum-sheet-on-plywood team moat?
GitHub
Unread 12-02-2016, 13:15
FRC #1836 (MilkenKnights)
A lot of teams are testing on bare plywood
Unread 12-02-2016, 13:55
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Early on in the season a student drove our prototype drive chassis over the rough terrain. He made it look so easy that I wanted to give it a try. I promptly beached the robot and damaged some of the rough terrain blocks in the process...
Unread 12-02-2016, 15:15
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
IMHO, the Moat is hard because the ramp leading up to it ends at the bottom of the vertical component of the Moat. This doesn't give your robot time to level out before its climbing again.
YMMV
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 12-02-2016, 16:22
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
I was really surprised with how easy the Rock Wall proved to be. Moat was surprisingly troublesome at first, but it doesn't take much to improve moat capabilities.
Most teams won't bother to make a complete set of defenses. I would bet many have not made all 4 of the B/D defenses. Many of the team-build defenses also have small inaccuracies- the rough terrain is the biggest offender.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 12-02-2016, 17:43
fputmustang3711's Avatar
fputmustang3711 fputmustang3711 is offline
AKA: Forrest Putnam
FRC #3711 (Iron Mustangs)
fputmustang3711 is an unknown quantity at this point
The one defense that has really gotten our team was the cheval de frise. It proved to team 3711's downfall. We were doing a test with a prototype when it went flying and made a very unsettling crash landing. That took a little time to repair.
Team 3711: Iron Mustangs
Unread 12-02-2016, 17:55
anishde's Avatar
anishde anishde is offline
FIRST? What's SECOND?
AKA: Anish De
FRC #5123 (Mechadogs)
anishde is on a distinguished road
Interesting to see the responses...has anyone actually built the drawbridge or sally port yet?
