Go to Post If you're doing it to win, you're doing it wrong. Teams who truly understand why they are doing what they do will win Chairman's simply as a result, an added benefit. The award isn't the goal. It's the impact you create, and the results you see. - dcarr [more]
Unread 13-02-2016, 05:30
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Bumper Number Material
I've been told that some teams use slicker bumper cloth to assist in escaping pins, but doesn't the bumper number material also change the coefficient of friction of the bumper? What is the best bumper number material/method to complement slicker bumpers?
On the other hand, what is the best bumper number material/method to complement rougher bumpers?
To start, one of our mentors speculated that sewn on numbers might be rougher because of the seams.
Unread 13-02-2016, 07:56
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
Re: Bumper Number Material
In the past my team has always painted on the letters with a stencil. They stayed on their I believe but it didn't look good. This year we are going to try to use HTV (Heat Transfer Vinyl), but the only problem is that there is a very thin margin of applying the vinyl, and melting the slick bumper material.
Unread 13-02-2016, 09:32
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Paint would probably be the slickest because it will leave a bit of the fabric still exposed. Vinyl has differing levels of friction on the surface. Some of the stretch vinyls for athletic jerseys are really rubbery and sticky, while the standard vinyls are all pretty slick. Cold peel vinyls are typically thinner and slicker than hot peel vinyls.
As to the melting of the fabric, use a heat press. Someone in your area has one. They have a temperature control that is the reason why they cost so much. My classroom press will stay within 5 degrees of the set temperature and the reported temperature is within one degree of actual. You can find the minimum temp to apply vinyl and the maximum temp the fabric can handle andsettle on somewhere in the middle.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
