Go to Post I think the answer you will get will be the same we have been saying since post #2 on page 1. - KenWittlief [more]
Unread 13-02-2016, 09:42
Kevin Pai's Avatar
Kevin Pai Kevin Pai is offline
FRC #5964 (Praetorians)
Rookie Year: 2015
Kevin Pai is an unknown quantity at this point
How to SetThrottle
We are using java to program our robot and we are trying to change the sensitivity of our motor controller. Is there a way to SetThrottle, and will that help to change the sensitivity? We see that there is a method called GetThrottle. If not, we are also looking at Setoutput, which seems to use binary.
Unread 13-02-2016, 10:13
Jalerre's Avatar
Jalerre Jalerre is offline
FRC #4965 (FIRE)
Jalerre is on a distinguished road
Re: How to SetThrottle
If I understand this correctly, you are trying to use the throttle on your joystick to control the speed of your motor. To do this you need to create a method to change value of the throttle from -1-1 to 0-1 using some simple math. Specifically you'd need to add one to the output of the throttle then divide by two. You then multiply this new value by the number you input as the speed for the motor controller. If you are using a joystick to control the motor, this will limit the speed of your motor but still give you the full range of the joystick. If you need some example code, I can provide it.
Vex
2013: 415 - Fabrication, Programming, Electrical
2014: 415D - Captain, Programming Lead
FTC
2014: 7354 - Programming Lead
FRC
2013: 415 - Safety Animation, Fabrication
2014-2015: 4965 - Programming & Electrical
2016: 4965 - Captain, Programming Lead, Electrical
