Go to Post Our role models are practical visionaries. That's the glue. - JaneYoung [more]
Unread 13-02-2016, 23:58
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
WCProducts MCC Question: how do you make your bumpers look so good?
I'd love to know the technique for bending the pool noodles in that nice radius. Teams who successfully do this, what are your secrets?
http://www.angelbotics.com
Remember why you're doing this.
Unread 14-02-2016, 12:24
DoxCoach599 DoxCoach599 is offline
Coach, Team 599 - The Robodox
AKA: Peter Beal
FRC #0599 (The Robodox)
DoxCoach599 is an unknown quantity at this point
Re: WCProducts MCC Question: how do you make your bumpers look so good?
I don't know how other teams do this, but typically, we cut a single piece of noodle and have it vertical as the corner of the bumper.
In terms of ASCII art, it would look something like this
Where "=" is a horizontal stack of two noodles
Unread 14-02-2016, 13:45
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We usually do mitered corners.
Supposition, not experience: Making a tight radius in noodle and having it look good would require reducing the size of the inside corner. This could be done by removal of material (kerfs or wedges) or by heating that causes the plastic of the noodle to shrink a bit. With either method, solid noodle seems more likely to make a good tight radius without flattening than a cored noodle.
Edit:
A better picture of this is in the game manual, Figure 4-8, bottom center.
Unread 14-02-2016, 16:02
mrnoble's Avatar
teacher/coach
So do we. But those tight, rounded corners look sooooo fresh. I want to try to figure them out.
