Go to Post What really drove us was not our achievements, but our failures. - BEEKMAN [more]
Unread 15-02-2016, 21:42
flipthedog's Avatar
flipthedog flipthedog is offline
Member of Team 1389
AKA: Floris
FRC #1389 (The Body Electric)
flipthedog is an unknown quantity at this point
Broaching Sprockets
Hello,
We might need to broach some of our steel sprockets, which already have a 1/2in hole, with a 1/2in hex broach. According to Andymark the broach will work on mild steel.
Does anyone have any experience with broaching steel sprockets? Will it work?
Thanks,
Floris
Unread 15-02-2016, 22:30
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Re: Broaching Sprockets
Yes. Hex or key broaching? If you are broaching a key, make sure you use no shims on the 1st plunge. then 1 shim and finally the 2nd. The shims should be part of your broach "kit." Hex broaching is a little easier, no shims needed.
2 things to remember, keep the tool straight so you get a straight key or hex perpendicular to the sprocket and use plenty of heavy oil for easier cutting and a better finish.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 15-02-2016, 22:34
flipthedog's Avatar
Member of Team 1389
AKA: Floris
Thanks for the reply, we are doing hex broaching. I'll try tomorrow and see how it goes.
Unread 15-02-2016, 23:11
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
It should go fine as long as you have a 3 ton or more arbor press, a strong person, and the length through bore is is between 1/2 and 3/4. Anything outside of that range will give you trouble. Also, make sure there are no set screws in it.
