Go to Post I survived the Great CD Spamming of 2006. - Michelle Celio [more]
Unread 16-02-2016, 18:20
mr_abomination mr_abomination is offline
FRC #4733
mr_abomination is an unknown quantity at this point
Can we run servo motors on something other than PWM?
Our team has run into the slight problem of using too many motors which all need independent control. We've doubled up where we can but 4 drive motors, 2 shoulder motors, 2 wrist motors, 2 shooter motors, 2 servos and a pulley quick. Because of this we have run out of PWM ports...
We are wondering if anyone knows a way we could use a different channel, say analog, to control our pair of servo motors. There's only two of them so modifying the base servo class isn't out of the question.
P.S. we're using C++ as our coding language.
Unread 16-02-2016, 18:38
Re: Can we run servo motors on something other than PWM?
Have you looked into this?
http://www.chiefdelphi.com/forums/sh...d.php?t=133143
Unread 16-02-2016, 21:50
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
You can use a PWM Y cable to control two motor controllers at once if they always have the same operation (like two motors on one side of a drive train).
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 16-02-2016, 22:22
Servos MUST be run from one of the regular roboRIO PWM ports (R54).
You can move motor controllers to the MXP PWM ports though.
Unread 17-02-2016, 13:34
anthonyttu anthonyttu is offline
Texas Instruments Engineer
AKA: Master Chief
FRC #5417 (Eagle Robotics)
anthonyttu has a spectacular aura aboutanthonyttu has a spectacular aura about
If you are using Tallon SRX's or Jaguars' you can control your motors with the CAN bus.
