Go to Post Our team is using a video camera with frame-by-frame analysis to figure out all the characteristics of the foam ball. If the Boeing engineer says it's possible, I'm going to believe him. - sciencenerd [more]
Unread 02-17-2016, 02:17 AM
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Next tools for 5940's machine shop
We are looking in to what tools to get next for our machine shop. Right now, the bigger tools we have are a bandsaw, drill press, and compound miter saw. As far as hand tools go we have a full assortment of drills, impact drivers, socket sets, screwdrivers, etc. Based on what we already have, what would you recommend our next tool purchases are? Thanks in advance.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 02-17-2016, 02:33 AM
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Re: Next tools for 5940's machine shop
If you want a bigger tool for your next purchase, go for a belt/disc sander, lathe, or mill depending on the budget. For hand held tools I recommend (if you don't have them already or don't mind more inventory) a grinder, drill bit sharpener, metal files, reciprocating saw, clamps, rubber mallets, center punches, scratch awls, squares, and calipers.
Also, lots and LOTS of sharpies.
Unread 02-17-2016, 10:15 AM
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
I would suggest the biggest lathe that your budget allows. Even a basic mini-lathe would allow you to machine custom drive shafts and spacers.
You should include a minimum set of tooling to get you started.
Cutting tools - Minimum of
AR & AL for 90° Edges and Faces
BR & BL for Turning edges
C for Flat side Turning
D for thread cutting
Cutoff tool
Tap & Drill Set for creating threaded center holes
If you don't have them already -
Digital Calibers
Dial Indicator
I'd also recommend a cutter set for C-Clip and E clip groves. but you could add that later.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 02-17-2016, 10:39 AM
mastachyra's Avatar
mastachyra mastachyra is offline
FRC #2781 (RoboPride)
mastachyra is just really nicemastachyra is just really nicemastachyra is just really nicemastachyra is just really nice
This year we fixed up an old bandsaw, and purchased a belt/disk sander combination. It seems like they revolutionized out fabrication abilities! We are pretty far from getting a lathe or mill, but I'd say our next step is a sheet metal brake. I also just purchased a step drill bit, and it is really nice to make clean and accurate holes.
I guess I'd recommend a sheet metal brake...
2014: EtaBot - MWR/30th place/no PO
2015: ThetaBot - MWR/30th place/no PO, R2OC/Winners, IndyRAGE 5th Alliance, WMRI QF
2016: IotaBot - MWR/16th place/QF, R2OC/7th Alliance Captain/QF, Boiler Bot Battle/6th place/Finalist
Unread 02-17-2016, 11:08 AM
Oblarg Oblarg is offline
AKA: Eli Barnett
Seconding the "lathe or belt sander" recommendation. Honestly, I'd say get a belt sander before a lathe, in terms of overall utility, but both are high on the list.
"The breakfast of champions!"
Unread 02-17-2016, 11:44 AM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Depends on what construction style you want to go after... The total effectiveness of a shop is not in the sum of the tools inside of it, but how those tools and the people work together to deliver a product, much like any design issue.
In no particular order:
Group 1: sheet metal/sheet plastic
CNC router/CNC Plasma
Sheet metal brake
Arbor press
Group 2: space-frame construction
Tube notcher
Tube bender
Iron Worker
Welder
Group 3: HOG IT OUTTA BILLET!
CNC/Manual Lathe
CNC/Manual Mill
We have access to all of these, and some more, in our shop. We mostly wind up using a CNC plasma cutter, CNC mill (as a CNC router), brake, welder, and a little bit of lathe work.
Unread 02-17-2016, 12:06 PM
Doiteain's Avatar
Doiteain Doiteain is offline
That tall guy over there
AKA: Cuyler
FRC #5026 (Iron Panthers)
Doiteain is infamous around these partsDoiteain is infamous around these parts
We're right down the road from Design Tech (at Burlingame High School), so if you want to stop by for inspiration based on what we've got in our lab we're happy to have you.
That being said, disc sander, CNC mill, and table saw would be the next few mchines to get (in order of how much we use them).
Unread 02-17-2016, 02:03 PM
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
We got a very old mill this past season. It is a small mill that fits on a cart and no digital readout. It has completely revolutionized how we make parts. It may be slow and the nicest but as somebody said above its how your team uses the tools and utilizes them. Our robot could not have been made this year without it.
In terms of new machines to get I would reccomend a table lathe or larger lathe if you have the money. Being able to make drive shafts and spacers is invaluable. Next I would get a good sander. After that I would say a mill of some sort. Ours only cost $2000 and that came with a large lathe and a large assortment of milling tools. Best of luck to you guys!
Unread 02-17-2016, 05:24 PM
RoboChair's Avatar
AKA: Devin Castellucci
Some of the highest things on my list would be as follows.
Non-ferrous cutting blade for your chop saw and a good clamping and work stop rig
Lathe
Manual mill
CNC router
I would look at buying used machines, California has a lot of quality used machines around especially in the Bay Area. I would love the chance to talk with you in depth about your many options for machines and tools. Send me a PM if you are interested. The same goes for anyone else reading this thread, I'm always game for talking shop and sharing how we run ours.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 02-19-2016, 02:03 PM
AKA: Eli Barnett
Could you provide an example of one of these? I've always just used chunks of 2-by-4 and C-clamps/bar clamps, if there's a better solution I'd love to know about it.
Unread 02-19-2016, 02:27 PM
RoboChair's Avatar
Originally Posted by Cory View Post
I'm glad you find utility in yours, but this design basically takes 3 individually crappy machines and mashes them up into one even crappier jack of trades machine.
If you're planning out future additions, find the money to buy quality standalone machines.
A strong second from me
We have a micrometer stop on ours mounted on a rod, we can put it close to where it needs to go and adjust the 1/2-20 screw to fine tune.
We have 2 4" stroke pneumatic pistons mounted on either side(actuated via foot switch) to clamp parts, but any semi-permanently mounted clamp that is quick and easy to use would fulfill this part. The key is clamping as close to the blade as you can to let you cut small parts.
I will take a picture of our set-up if I remember this weekend, but I think our prototyping workshop vid on YouTube has it in the video.
Unread 02-18-2016, 12:06 AM
daliberator's Avatar
daliberator daliberator is offline
Ace Machinist
AKA: Henry O'Callaghan
FRC #4536 (MinuteBots)
daliberator will become famous soon enoughdaliberator will become famous soon enough
This is a really good point. A CNC router is just a really expensive paperweight if nobody knows how to use it properly.
Ditto on the belt/disk sander recommendation. We got one this year and it has made a surprisingly large impact on our manufacturing process. Also, having a relatively cheap/small sheet metal brake (Like this one) has really changed the way we design. Our chassis this year wouldn't have been possible without it.
4536 Team Captain
www.minutebots.org
Unread 02-18-2016, 08:36 AM
TNT280Staff's Avatar
TNT280Staff TNT280Staff is offline
AKA: Joe Horth
None #0280 ("TnT")
TNT280Staff is a jewel in the roughTNT280Staff is a jewel in the roughTNT280Staff is a jewel in the roughTNT280Staff is a jewel in the rough
If it is within your teams budget, I would highly recommend getting one of these
http://www.smithy.com/granite-3-in-1...FYkCaQode1IK-w
We use ours daily.
"TnT" 280 - Taylor, Michigan
Unread 02-18-2016, 03:58 PM
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
We use ours daily.
2001-2004: Team 100
2006-Present: Team 254
Unread 02-18-2016, 04:23 PM
JDGallagher's Avatar
JDGallagher JDGallagher is offline
AKA: John Gallagher
FRC #1086 (Blue Cheese)
JDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of light
I would just go for the best lathe you can afford with some basic tooling and a retaining ring groove tool. Good pair of calipers and dial indicator if you don't already have them.
