Go to Post A lot of students decribe FIRST as the best thing that happened to their life. Once a student gets hooked, they don't want to leave FIRST for any cause. I am one of them. - Arefin Bari [more]
Unread 17-02-2016, 14:40
crollison crollison is offline
AKA: Chris Rollison
FRC #4809 (Black Knight Robotics)
crollison is an unknown quantity at this point
Gauge Locations
Does the Stored or Working gauges have to be directly connected to the regulator or in line with the compressor to the relief valve? The question is, can the gauges be put somewhere else and tubing connect them into the right order? They would be properly marked. thanks.
Unread 17-02-2016, 15:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Gauge Locations
I haven't seen any rules about the locations or connections of pneumatic components, aside from the location of the pressure relief valve required to be on the compressor, and the fact that you need to use parts that are rated for the pressure.
So I would relocate them as you find necessary.
Unread 17-02-2016, 23:56
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Gauge Locations
We have traditionally mounted them to a manifold/tee on the compressor and one of the regulator outputs to minimize connectors. However, putting them where they are visible is probably more important than minimizing tubing runs, especially if these runs do not carry air on its way to a solenoid valve, but are "dead ends" of the air distribution system.
Unread 18-02-2016, 05:08
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Gauge Locations
Gages need to be where the can be easily read. Making the tubing so it can be easily traced good practice.
