Go to Post Don't underestimate the ability of a highly skilled technician with simple tools (and don't overestimate the ability of an unskilled fool with exotic tools!). - dlavery [more]
Unread 18-02-2016, 17:33
hutchMN hutchMN is offline
2502 alumnus
FRC #4360
hutchMN has a spectacular aura abouthutchMN has a spectacular aura abouthutchMN has a spectacular aura about
teaser of 2502's robot
I posted this video a couple days ago on a different thread, but I wanted to create a thread for it so I can hear your feed back on how you think we could improve our design and maybe help the community a little bit (i know it's pretty late). We are about done with our climber that isn't shown in the video but hopefully it will be sub 5 seconds. We're currently beefing up our active intake to hopefully better deal with defense. We have no plans of going under the low bar and the rods have been fixed to fit inside the height regulations. Any suggestions would be helpful and I'm also more than willing to answer any questions you might have.
https://www.youtube.com/watch?v=3RDTD9K0q1U
Unread 18-02-2016, 17:38
GabbySaurus's Avatar
GabbySaurus GabbySaurus is offline
Magical Space GabbySaurus
AKA: Jaquanis
FRC #3452 (GreengineerZ)
Team Role: Driver
GabbySaurus is an unknown quantity at this point
Re: teaser of 2502's robot
This robot is incredible and the shot is so perfect!!!!!!
Unread 18-02-2016, 17:39
Chris Mounts's Avatar
Chris Mounts Chris Mounts is offline
FRC #1188 (Oaktown Crewz)
Chris Mounts is an unknown quantity at this point
Looks great! One question though. How will you insure the fibreglass 'antennas' don't travel more than 15" outside your frame? We're trying to figure this out right now for our bot.
Unread 18-02-2016, 17:51
sagi34 sagi34 is offline
FRC #2231 (OnyxTronix)
sagi34 is an unknown quantity at this point
what do the 'antennas' do? why do you even need these on your robot?
Student: 2013 - 2015
Mentor since 2016
Unread 18-02-2016, 18:18
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
My guess would be for better visibility of a short robot across a field with tall obstacles. I know we're doing something similar for that reason.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 18-02-2016, 18:39
Ian Good's Avatar
Ian Good Ian Good is offline
Senior Tech. Advisor
FRC #2930 (The Sonic Squirrels)
Ian Good will become famous soon enough
Great looking robot!
I love the antennas on top of the bot for visibility, I think it will help a lot.
If you are worried about your antennas extending outside of your frame perimeter, you could make them shorter and center justify them on the robot.
Have you considered what would happen if someone runs into the bot at the moment you pick up the boulder? it looks like it might escape out the top/sides.
It seems like you have good control when the boulders enter the robot though
I am really digging that shot, but you should watch out for ware and tear over the season as it may reduce the energy that you are able to transfer to the ball.
Unread 18-02-2016, 19:25
2502 alumnus
FRC #4360
The rods were mounted with duct tape at the time of this video as a proof of concept. We have since made better mounts for them and have decreased their length to help prevent them from extending beyond 15 inches. Worse case we can use a more solid rod because we don’t plan on going underneath anything. We have polycarbonate sides on the intake so the ball can’t escape, it’s just hard to see in the video. Thanks for all the input.
Unread 18-02-2016, 20:47
Roboshant's Avatar
Roboshant Roboshant is offline
Design Lead 17, Scouting Captain 16
AKA: Dikshant Sharma
FRC #0226
Rookie Year: 2015
Roboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to all
Is that reflective tape near the top of the fiber glass rods? If so, you might jam the vision sensing for some robots (not completely sure). Doing this is also against R9 as C clarifies in the blue box.
Unread 18-02-2016, 20:56
2502 alumnus
FRC #4360
That part is no longer on the rod, we made the rods shorter (after the video was filmed) and that part was cut off in the process. Thanks for the feedback
Unread 18-02-2016, 22:19
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
What exactly are the rods and what are they made of? And are they rigidly mounted at the base?
We've been trying to find something like that but haven't found anything flexible enough. And I'm not yet in love with a tilting spring-loaded base.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 18-02-2016, 23:00
anishde's Avatar
anishde anishde is offline
FIRST? What's SECOND?
AKA: Anish De
FRC #5123 (Mechadogs)
anishde is on a distinguished road
Great job, guys! Clearly your work with Aerial Assist helped you out on this one...
Unread 19-02-2016, 01:02
2502 alumnus
FRC #4360
We got most of our inspiration from team 16's 2012 robot.
Unread 18-02-2016, 17:49
RoboTigers1796 RoboTigers1796 is offline
FRC #1796 (RoboTigers)
RoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of light
Looking good! Are the rods there solely to help travel under the portcullis?
2014 Attended: NYC Regional, SBPLI Regional NYC Regional- Imagery Award in honor of Jack Kamen
2013 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- Gracious Professionalism Award sponsored by Johnson & Johnson,SBPLI Regional- #4 Alliance Captain & Regional Winner- With our impeccable alliance 358 and 3171
2012 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- #7 Ranked Seed & Semi-Finalists, SBPLI Regional- #3 Seed & Regional Winner- With our very awesome alliance 527 and 870, Industrial Design Award sponsored by General Motors
2011 Attended: NYC Regional, SBPLI Regional SPBLI Regional- Xerox Creativity Award and #5 Alliance Captain
2009 Attended: NYC Regional, FIRST Championships NYC Regional Winner- With our amazing alliance 1807 and 56
Unread 18-02-2016, 23:43
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
You can get the rods at homedepot or Lowes they are driveway markers.
Unread 18-02-2016, 23:48
Really? The driveway markers at the nearby Tractor Supply seem much stiffer than what's in the video.
