Go to Post A lot of people forget this when posting, but your posts here on ChiefDelphi will more or less be here forever. Do you really want that post you just be made to be on the Internet forever?... Post wisely... - artdutra04 [more]
Unread 02-19-2016, 11:14 PM
Cubby Cubby is offline
FRC #4598
Cubby is an unknown quantity at this point
PID Problems
Hey guys! I'm a senior from Salt Lake just getting into FIRST. I am new to java and I'm having some trouble specifically with my PID loop. As I understand it the PIDController function should take input from my encoder and send output to my motor (arm). The code builds with no errors but I am seeing no motion in the arm motor, I am using an encoder value of 250 as my setpoint just for testing purposes. If anyone can lend me some advice as to how I'm screwing this up that would be greatly appreciated!
package org.usfirst.frc.team4598.robot;
import edu.wpi.first.wpilibj.CameraServer;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.CounterBase.EncodingType;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.PIDController;
import edu.wpi.first.wpilibj.PIDOutput;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
import edu.wpi.first.wpilibj.DigitalInput;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class Robot extends IterativeRobot // w/ joysticks
	CameraServer server;
	Joystick controller = new Joystick(0);
	Solenoid Punch = new Solenoid(1,3);
	Victor leftDrive0 = new Victor(0);
	Victor leftDrive1 = new Victor(1);
	Victor rightDrive0 = new Victor(2);
	Victor rightDrive1 = new Victor(3);
	Victor launchWheel0 = new Victor(4);
	Victor launchWheel1 = new Victor(5);
	Victor arm = new Victor(6);	//Shooter Arm
	Victor pnuarm = new Victor(7);
	Encoder encoder = new Encoder(1,2,true,EncodingType.k4X);
	double Kp;
	double Ki;
	double Kd;
	PIDController armPID = new PIDController(Kp,Ki,Kd,encoder,arm);  //PID (P,I,D,INPUT,OUTPUT)
	DigitalInput limitSwitchOut = new DigitalInput(3);
	DigitalInput limitSwitchIn = new DigitalInput(4);
	Compressor Compressy = new Compressor(1);
	int autoLoopCounter;
     * This function is run when the robot is first started up and should be
     * used for any initialization code.\
    public void robotInit()
		Compressy.setClosedLoopControl(true);
    	CameraServer server = CameraServer.getInstance();
    	server.setQuality(50);
    	server.startAutomaticCapture("cam0");
    	encoder.startLiveWindowMode();
    	armPID.enable();
    	armPID.setInputRange(0, 550);							    	    	   armPID.setOutputRange(-1, 1);
    	armPID.setAbsoluteTolerance(5);
    	armPID.startLiveWindowMode();
     * This function is run once each time the robot enters autonomous mode
    public void autonomousInit()
     * This function is called periodically during autonomous
    public void autonomousPeriodic()
     * This function is called once each time the robot enters tele-operated mode
    public void teleopInit()
     * This function is called periodically during operator control
    public void teleopPeriodic()
    	armPID.setSetpoint(250);
    	SmartDashboard.putNumber("L Trigger Value", controller.getRawAxis(2));
    	SmartDashboard.putNumber("Encoder Value", encoder.getRaw());
    	SmartDashboard.putNumber("Kp", Kp);
    	SmartDashboard.putNumber("Ki", Ki);
    	SmartDashboard.putNumber("Kd", Kd);
    	SmartDashboard.putNumber("ARMPID", armPID.get());
    	SmartDashboard.putNumber("ARMPID6", armPID.getSetpoint());
    	SmartDashboard.putBoolean("ARMPID7", armPID.onTarget());
    	Kp = .1;
    	Ki = .1;
    	Kd = .1;
    	//arm.set(controller.getRawAxis(2));
    	if (controller.getRawButton(2))
    		pnuarm.set(.85);
    	else if (controller.getRawButton(3))
    		pnuarm.set(-.85);
    	else
    		pnuarm.set(0);
    	if (controller.getRawAxis(3) > .5)
    			launchWheel0.set(.5);
    			launchWheel1.set(-.5);
    	else if(controller.getRawButton(6))
    			launchWheel0.set(-1);
    			launchWheel1.set(1);
    	else
    			launchWheel0.set(0);
    			launchWheel1.set(0);
    	if (controller.getRawButton(1))
    		Punch.set(true);
    	else
        	Punch.set(false);
    	//Drive
    	leftDrive0.set(-controller.getRawAxis(1));
    	leftDrive1.set(-controller.getRawAxis(1));
    	rightDrive0.set(controller.getRawAxis(5));
    	rightDrive1.set(controller.getRawAxis(5));
    	arm.set(armPID.get());
    	//if  (controller.getRawButton(4))
    		//if (encoder.get() < 530)
    	    	//arm.set(controller.getRawAxis(2)+.4);
    		//else
    			//arm.set(0.1);
     * This function is called periodically during test mode
    public void testPeriodic()
    	LiveWindow.run();
Unread 02-20-2016, 02:05 AM
mmaunu's Avatar
mmaunu mmaunu is offline
FRC #2485 (W.A.R. Lords)
mmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the rough
Re: PID Problems
I am on mobile so I apologize for this being short. In teleopPeriodic, get rid of the line that says arm.set(). You do not want to directly control the motor that the PID is controlling as they will fight each other. The reason that the PID is not doing anything, is because you constructed it with a KP, kI, and kD of 0. Right above the constructor for the PID controller, you declare those variables but you never give them values. I would start with a P term of ...well I have no idea... but start with a P term that is small like .01 or even smaller like .005. Increase your P term until you get motion that is close to your desired result or perhaps a little bit of overshoot if that is OK. If your P term is too large then you will over shoot your target and it will oscillate. If you don't want it to over shoot the target make the P term smaller, in which case it might stall out. You can add a D term to help with oscillation or an I term to help a stalled out process.
Good luck.
2014 Las Vegas (Winners with 987, 2478; Excellence in Engineering)
2014 San Diego (Finalists with 987, 3250; Quality Award)
2013 Inland Empire (Winners with 1538, 968; Excellence in Engineering Award)
2013 San Diego (Finalists with 2984, 4322; Creativity Award)
2012 Las Vegas (Finalists with 2034, 3187; Quality Award)
Unread 02-20-2016, 05:12 PM
FRC #4598
Re: PID Problems
Thanks so much! Its working great now just need to tune haha
Unread 02-21-2016, 01:57 AM
FRC #4598
Re: PID Problems
Hi, same topic different problem. I have tuned my P to .06 and my D to .005 which seems to work fairly well. The arm can quickly find and hold its position but it will periodically spike, I know some amount of this is normal but if anyone has any suggestions I would really appreciate the advice! Here's a video:https://youtu.be/_GVL4oMagSA
