Go to Post Yes, I'll admit it...I had a crush on Ken Leung when we all went out together for the college night in 2002. - Elgin Clock [more]
Unread 20-02-2016, 14:56
Trinitrotoluene's Avatar
Trinitrotoluene Trinitrotoluene is offline
FRC #3102 (Nevis Tech-No-Tigers)
Trinitrotoluene is an unknown quantity at this point
Difficulties setting output to Talon SRX?
Hi all,
We are using Talon SRXs with CTR magnetic encoders this year to control an arm. I've successfully set the reference to the magnetic encoders and am writing the encoder position to the dashboard.
However, when I try to set output to the Talon using the Motor>Set Output block, I can't get anything to happen. There is no response from the Talon whatsoever. I am attaching the block on the end of the Talon Get Status, which is working.
Any ideas? I've attached an image of my code below. Thanks!
Unread 20-02-2016, 15:03
Caboose's Avatar
Caboose Caboose is offline
Programmer - LabVIEW, C++, C#, Java
AKA: James Parks
FRC #0900 (Zebracorns)
Caboose has a spectacular aura aboutCaboose has a spectacular aura about
Re: Difficulties setting output to Talon SRX?
Are you using %Vbus to control the talon? If you are trying to use Speed or Position you are telling it to move +/- 1 native units.
navX Labview Library
"Robots are aluminum shavings, held together by zip-ties."
myManga
Unread 20-02-2016, 15:09
Position. I'll switch it and give that a try.
Unread 20-02-2016, 15:54
Caboose's Avatar
AKA: James Parks
You should also read the Talon SRX software reference manual.
http://www.ctr-electronics.com/contr...ical_resources
myManga
Unread 20-02-2016, 18:13
That appears to be working. I'll re-read the manual. Thanks!
