AndyMark 8 Inch pneumatic hub fail
All,
We took apart our drivetrain to give it some TLC today and discovered all of our 8 inch pneumatic hubs are failing. Very similar to the rhino tread pulleys. If you are using them, I suggest you take a close look are your hubs. I just sent pictures to AndyMark and we awaiting for a reply. Locktite was just applied, it was not there before about an hour ago. http://imgur.com/a/DX4OH Last edited by Fusion_Clint : 21-02-2016 at 14:53. |
Re: AndyMark 8 Inch pneumatic hub fail
Is that loctite on the nuts? Loctite will destroy the polycarbonate hubs.
They're failing because you put loctite on your screws.
You shouldn't have done that for 2 reasons, the first being that loctite will melt the plastic, the second being that it's pointless because you're using nylock nuts. |
Even have been using these hubs successfully without using any loctite.
It seems like this isn't Andymark's fault. |
The locktight was just applied to get through the next couple of days!
The damage goes all the way through the hubs. I highly suggest everyone using these take to a look at your hubs. |
You don't need loctight when you use nylock nuts...
Looking at how much excess loctite is on the hub, that damage could have easily been done by a combination of chemical breakdown and stress on the plastic. |
#7
Locktite was just applied, it was not there before about an hour ago. After the damage was found a student put the locktite on in an act of desperation.
#8
What did you anticipate loctite helping with that the lock nuts weren't already doing for you?
#9
Everyone, please read the thread BEFORE responding.
The Locktite was added AFTER the failure. It is NOT the cause of the failure. I believe the nylock nuts may have actually contributed to the failures. Some nylock nuts have larger outside dimentions than the comparable regular nuts. Forcing the larger nut into the hex opening, and over tightening them may crack the polycarbonate. |
#10
[edit] On closer inspection there are some cracks around the nut cavities that look like they might be consistent with slightly too large of a nut. Last edited by Cory : 21-02-2016 at 17:19. |
#11
Look, I'm not trying to get anything other than the word out to check your hubs.
The locktite was applied after the fact. We are fixing our issue, just make sure you don't have the same one. |
#12
Forcing in nuts that are too large for the opening can crack the polycarbonate too. Just my $.02. |
#13
Sorry for our ignorance. We simply did not know that loctite eats away at polycarbonate. We are currently looking at other options. EDIT: Another thing. The center hubs (6 wheel 1/8" center drop) were not damaged as much as the outside hubs. We have been stress testing our robot by hitting defenses as much as possible. Last edited by Landonh12 : 21-02-2016 at 17:45. |
#14
How much air pressure did you fill your tires to? Did you check the outsides of the hubs as well (take the tire off and really check)? I would be curious if there was any impact directly to the wheel itself that wasn't absorbed by the tire due to a low pressure situation. |
#15
Thanks for the heads up. I can see the barriers being the main culprit due to the stress on the wheels and not be surprised if that ends up being the case.
We've broken plaction wheels before in 2010. It's a good thing we decided to machine our own rims. |
