Go to Post ...when you see someone post about something they don’t like, please don’t post another “I’m sick of all this whining” type of post. If you disagree with them, try to offer an intelligent argument back. - Phil 33 [more]
Unread 02-22-2016, 09:19 PM
josephno1's Avatar
josephno1 josephno1 is offline
FRC #3647
Rookie Year: 2015
josephno1 is an unknown quantity at this point
ADIS16448 reading y values
Alright so I have downloaded this file
https://github.com/juchong/ADIS16448...16448_IMU.java
Anyways I want to access the method
  public synchronized double getAngleY() {
    return m_integ_gyro_y;
So in my Robot.java file I added the line
SmartDashboard.putNumber("IMU",imu.getAngleY());
Here the except of the code where that is from
package org.usfirst.frc.team3647.robot;
import edu.wpi.first.wpilibj.BuiltInAccelerometer;
import edu.wpi.first.wpilibj.Compressor;
//import edu.wpi.first.wpilibj.DriverStation;
//import edu.wpi.first.wpilibj.CANTalon;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.command.Command;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.smartdashboard.*;
import org.usfirst.frc.team3647.auto.*;
import org.usfirst.frc.team3647.subsystems.ADIS16448_IMU;
//import edu.wpi.first.wpilibj.Joystick;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class Robot extends IterativeRobot {
	public static boolean shootTest = false;
	public static boolean shootTest1 = false;
	Compressor c = new Compressor();
	private BuiltInAccelerometer accel = new BuiltInAccelerometer();
	ADIS16448_IMU imu=new ADIS16448_IMU();
	Command autonomousCommand;
	SendableChooser autoChooser;
	 * This function is run when the robot is first started up and should be
	 * used for any initialization code.
	public void robotInit() {
		updateDashboard();
    	autoChooser = new SendableChooser();
    	autoChooser.addDefault("Default Autonomous", new Default());
    	SmartDashboard.putData("Autonomous mode chooser", autoChooser);
    	System.out.println("The Robot is ready");
	 * This function is called periodically during autonomous
	 public void autonomousInit(){
	    	//resetAndDisableSystems();
	    	autonomousCommand = (Command) autoChooser.getSelected();
	    	autonomousCommand.start();
	public void autonomousPeriodic() {
		Scheduler.getInstance().run();
    	updateDashboard();
	 * This function is called periodically during operator control
	public void teleopPeriodic() {
		// resetAndDisable();
		updateDashboard();
		LogitechJoystick.controllers();
		Drivetrain.arcadeDrive();
		ShooterAngleMotor.angleShooter();
		BallShooter.shootBalls();
	 * This function is called periodically during test mode
	public void testPeriodic() {
	public void resetAndDisable() {
		// BallShooter.LShooter.set(0);
		BallShooter.rShooter.set(0);
		ShooterAngleMotor.angle.set(0);
		// Piston.BallShooterPiston.set(0);
	public void updateDashboard() {
		SmartDashboard.putData("IMUs", imu);
		imu.updateTable();
		System.out.println(imu.getAngleY());
Unread 02-23-2016, 05:22 AM
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
Re: ADIS16448 reading y values
I don't have any experience working with this sensor (my disclaimer), however in looking at the source, I did notice two things to check:
  1. Did you connect your sensor to the SPI pins on the expansion port (the MXP port)? This looks like what the default constructor expects. If you have connected your sensor to the main SPI port on the roboRIO, you may need to change line 117 in ADIS16448_IMU.java.
  2. When you put your driver station in test mode, do you see the "ADIS16448_IMU" object displayed and does it report angle information?
Finally, you may want to see if there are any error messages or stack trace dumps in the driver station console (or riolog viewer) to help track down where things are going bad.
Unread 02-23-2016, 11:27 AM
josephno1's Avatar
FRC #3647
Rookie Year: 2015
I'll try putting it on test once I get to work the robot today.
The sensor is plugged in on the custom electronics port
