Go to Post FIRST may very well be the healthiest drug on the market. - Herodotus [more]
Unread 02-22-2016, 10:28 PM
peterl peterl is offline
AKA: Peter Laser
FRC #1592 (Bionic Tigers)
peterl is an unknown quantity at this point
Question Need help with Network Tables
I have no experience with Network Tables. I need to send an 2d array to a LabVIEW dashboard using network tables, and I don't quite know where to start.
public java.lang.Boolean[] getBooleanArray(java.lang.String key,
                                           java.lang.Boolean[] defaultValue)
I found that on the Java Docs on: https://team2168.org/javadoc/
If someone used Network Tables to comunicate to a dashboard last year and could post that code, I think I could gain a further understanding of network tables from that.
Thanks.
Unread 02-23-2016, 02:05 PM
fireXtract fireXtract is offline
MegaHertz_Lux
FRC #2847 (Mega Hertz)
fireXtract is an unknown quantity at this point
Re: Need help with Network Tables
For my usage I use:
	public NetworkTable table = NetworkTable.getTable("locationOfItem");
			actualVariable = table.getNumberArray("arrayItem", defaultValue);
			SmartDashboard.putNumber("displayName", actualVariable[0]);
This uses arrays, but you could use it with just numbers by using different getNumber with table.
Unread 02-23-2016, 11:27 PM
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
We just got support for 1D arrays this year, I don't think 2D arrays are currently viable (unless the above poster's solution works for you)
if you ABSOLUTELY need a table, and you can do some data processing on the dashboard (not familiar with configuring the lv dashboard), than you can always send the data as a string encoded with the raw bytes of the 2D array
Unread 02-24-2016, 10:32 AM
AKA: Peter Laser
I didn't realize that. If I can send 2 1D arrays, I can combine them to create a 2D Array. I will see about trying fireXtract's method.
Unread 02-24-2016, 12:22 PM
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
It depends on the scope of your project. If it is a static amount of arrays than yes you could always just use 5 different 1D arrays.
