Go to Post Lesson learned, /always/ have a pick list! - Lil' Lavery [more]
Unread 23-02-2016, 13:05
Ichlieberoboter's Avatar
Ichlieberoboter Ichlieberoboter is offline
Awards and Programming
AKA: Maria Valentini
FRC #2499 (Industrial Revolution)
Ichlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud of
Adding more motors for tank drive
This is the first time our team is using python and we've been trying to figure out how to change our original code that had a cim on each side to having two cims on each side. It's probably not that complex but we don't understand the software super well. We need the new cims to be inverted.
Team 2499-Industrial Revolution
2015 Lake Superior Regional Judges Award
Head Programmer Chairman's Award Presenter Awards Submitter Electrical Team Website Designer Strategy Team
Unread 23-02-2016, 13:08
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Adding more motors for tank drive
Not familiar with Python, but it should be as simple as either adding 2 new speed controller objects to your RobotDrive object, or if you aren't using a robotdrive object, just add 2 more motor controllers and address them like you do the other 2.
Edit: You might need to add a constructor inside of the robotdrive class that accepts 4 speed controllers, and assigns them to each side of the robot correctly.
Post your code?
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 23-02-2016, 13:10
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
In any language, it's just a matter of telling the RobotDrive object to use multiple motors. Check out the docs at http://robotpy.readthedocs.org/en/la...obotDrive.html
The great thing about using python is the pyfrc simulator... the simulator has full support for 4-motor drivetrains too. Check out this physics example: https://github.com/robotpy/pyfrc/tre...physics-4wheel
Unread 23-02-2016, 13:28
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Alternatively you could keep the code the same and run y splitters for the pwm ports.
461 Westside Boiler Invasion
45 Technokats
Unread 23-02-2016, 13:31
AKA: Matt B
FRC #1771 (1771)
Assuming they aren't using CAN. But they also need the CIMS to be inverted, although they can just reverse the polarity from the speed controller output.
1771- Mentor (2015)
Unread 23-02-2016, 14:01
45 Alumni
AKA: Peyton Yeung
If the motor is on the same side as the motor it is getting y connected to then it shouldn't need to be inverted unless the internal coil was reversed.
45 Technokats
