Go to Post When mentors and students battle it's the team that loses. - Koko Ed [more]
Unread 23-02-2016, 13:38
SandraM6046's Avatar
SandraM6046 SandraM6046 is offline
FRC #6046 (King Tech)
Rookie Year: 2016
SandraM6046 is an unknown quantity at this point
Question BATTERY TRAY HELP
My team got a battery tray and we were wondering if it was mandatory to use it. We found the diagram to put it together, but the way the tray is set up, interferes with our chassis.
Unread 23-02-2016, 13:39
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: BATTERY TRAY HELP
No, there is no specific battery tray that you are required to use.
But you need to secure the battery well. How you do it, is up to you.
Unread 23-02-2016, 13:41
Rookie Year: 2016
Thank you very much!
Unread 23-02-2016, 13:44
TogetherSword8 TogetherSword8 is offline
FRC #0888 (Robotiators)
TogetherSword8 is an unknown quantity at this point
There are no rules on any required components except the roborio, power distribution board etc.
You are allowed to use any method to mount and hold your battery and any other components. However, I would recommend that you do make sure you have a secure method of holding your battery. If a referee sees a battery flying around in your robot, you may get automatically disabled due to a safety hazard.
I program a robot. Which means I write code and everyone gets mad at me when something doesn't work, even if I am the only one that knows it doesn't work. The key part to know is that the robot never works.
Unread 23-02-2016, 13:56
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
FYI: The battery must be secured on all 6 sides. Per the rule, the battery must be secure in any arbitrary orientation of the robot (incase it falls over, etc.). Which means, secured on all 6 sides.
