Go to Post Everyone's bored, what else do we have to do in the off season? - StephLee [more]
Unread 23-02-2016, 14:15
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
Pneumatic Pressure Gauges and Relief Valve?
My team finally had a chance to charge the pneumatic system yesterday. We were losing air fast.
They tried using soapy water, but did not find anything.
When I arrived and was told about the issue, my first action was to look at the connections and retape and tighten them down properly. The second action was to verify that the tubes were cut straight.
We are still losing air fast, but it seemed to settle around 20psi on both gauges. I'm wondering if we need to adjust the pressure gauge and/or relief valve. If so, do we do both? If we do both, is there a particular order to do them in?
Thanks,
indieFan
Unread 23-02-2016, 14:22
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Pneumatic Pressure Gauges and Relief Valve?
Is your regulator properly? It sounds like you may have set it up backwards.
2016: Lake Superior WFFA
Unread 23-02-2016, 14:23
FRC #5941
Not sure. I'll double check this tonight when I go.
Unread 23-02-2016, 14:25
dtengineering's Avatar
AKA: Jason Brett
Team 6008 fired up their pneumatics last night and noticed something similar. Their pressure relief valve seemed to be relieving itself a bit too easily.
The rules do allow teams to calibrate their pressure relief valves as "they may not have been correctly calibrated at the factory" (or similar words).
That may be part of the problem you are seeing.
Jason
