Go to Post Please review the rules for posting. - meaubry [more]
Unread 02-24-2016, 07:43 PM
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Running two commands in sequence from SendableChooser
Hello, I am having trouble with auto choosers in the smartdashboard. I have two sendable choosers (one for obstacles and one for goals). When I run the code, the commands work like they should, but when autonomous mode ends, the code crashes with no errors.
Here is a snippet:
Robot.cpp:
void Robot::AutonomousInit() {
	selectedObstacle = (Command*) chooserObstacle->GetSelected();
	selectedGoal = (Command*) chooserGoal->GetSelected();
	selectedObstacle->Start();
void Robot::AutonomousPeriodic() {
	Scheduler::GetInstance()->Run();
	if(selectedObstacle->IsRunning() == false) {
		selectedGoal->Start();
void Robot::TeleopInit() {
	if (selectedObstacle != nullptr) {
		selectedObstacle->Cancel();
	if (selectedGoal != nullptr) {
		selectedGoal->Cancel();
My guess is that the robot is confused because the command group was cancelled? Does a command group get cancelled?
Thanks,
Drew
