Go to Post Let's let FIRST bring us together as a whole rather than separate us into parts eh? - sanddrag [more]
Unread 25-02-2016, 15:51
tyler9698's Avatar
tyler9698 tyler9698 is offline
AKA: Left Hook
FRC #5624 (Tiger Tech)
tyler9698 is an unknown quantity at this point
Roborio not recieving power
Our freshman are working on our team's 2015 recycle rush robot. Everything is wired correctly and the roborio is not receiving power. We have narrowed down the problem to the pdp wire slots on the pdp. Does anyone know of anyways to either clean these slots or make the wire stay in.
Unread 25-02-2016, 16:24
lethc's Avatar
lethc lethc is offline
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
lethc will become famous soon enough
Re: Roborio not recieving power
Check your red fuse.
2016: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Semifinalists, IRI Quarterfinalists
2015: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Quarterfinalists, IRI Winners
2014: Central Illinois Regional Quarterfinalists, Greater Kansas City Regional Finalists, Newton Semifinalists
2013: Greater Kansas City Regional Winners, Oklahoma Regional Winners, Galileo Quarterfinalists
Unread 25-02-2016, 16:25
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Are you using the correct wire size? Your wire might be too small. If you do have the correct wire size, then tinning the wire with soldier will make it bigger, and possibly hold better in the PDP connector slot.
Unread 25-02-2016, 22:13
If there is no voltage on the PDP's roboRIO connections, the 10A red minifuse is probably blown.
If there is battery voltage but it's not getting to the roboRIO, look to the wires. Make sure they're stripped to the right length, inserted fully, and clamped properly in the Weidmuller connectors.
