Go to Post But if we just re-play "Triple Play" then what in the world will the Game Design Committee do with all that new-found free time? Since they wouldn't have to come up with a new game, they would have to concentrate on other things - like how to enforce the proposed "no metal on robots" rule. - dlavery [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 28-02-2016, 14:17
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
STEM Quiz #1
Here's a quiz that's mostly geometrical, but you may need to do a bit of mechanical/engineering research to get to the answers.
The Vex Versaplanetary gearbox offers single stages ranging from 3:1 reduction down to 10:1 reduction. These gearboxes are driven at the sun gear, have a fixed annular gear, and drive output on the planetary carrier. Assuming that there are at least three planet gears of the same size as each other, what are the theoretical highest and lowest possible reductions possible for a single stage gearbox of this type? For purposes of this calculation, you may allow the teeth to be infinitesimally small, so that this becomes a "roller box" rather than a gear box.
As with Ether's quizzes, I'm not looking for full mathematical rigor, but show enough of your work that I can tell where your numbers are coming from.
Unread 28-02-2016, 17:03
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Re: STEM Quiz #1
The lower limit as Sun Gear diameter approaches Ring Gear diameter should be 2:1, as the ratio for a planetary gearbox as described is R/S+1.
The upper limit requires some geometry constructions of 3 equally spaced tangent inscribed circles. My literal back of the envelope derivation got messy, but the result came out to 1/(1-6/(3+2*sqrt(3)))+1 or 14.928203235:1
I'll try to post a coherent derivation when I get it worked out nicely on something more legible.
I should point out that these are the limits of the ratio, rather than achievable ratios under the stated conditions, as you would have gears or rollers moving in opposite directions in direct contact.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 28-02-2016, 22:02
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: STEM Quiz #1
The upper limit requires some geometry constructions of 3 equally spaced tangent inscribed circles. My literal back of the envelope derivation got messy, but the result came out to 1/(1-6/(3+2*sqrt(3)))+1 or 13.928203235:1
Correct on the limit of large sun gear is 2:1. On the lowest gear ratio, you're quite close but not quite right.
Unread 28-02-2016, 23:00
MechEng83's Avatar
AKA: Mr. Cool
Re: STEM Quiz #1
Forgot the plus 1 in my calculator when transcribing the upper limit. Should be 14.9282032303:1
Red Alert Robotics
Unread 28-02-2016, 23:11
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: STEM Quiz #1
That's the correct numeric value (with way more significant figures than I calculated), but still waiting on a proof.
Unread 29-02-2016, 00:36
MechEng83's Avatar
AKA: Mr. Cool
Re: STEM Quiz #1
Here's my MS Paint proof. I did the ratio in terms of radii of the gears.
Red Alert Robotics
Unread 28-02-2016, 17:13
MechEng83's Avatar
AKA: Mr. Cool
Re: STEM Quiz #1
Side note: I think it's beautiful that the ratios offered are all clean integer ratios*, not messy repeating decimals. Planetary gear boxes of this variety have single stage ratios of Ring Gear Teeth/Sun Gear Teeth +1. The ring gears on Versaplanetaries are 72 teeth, which has factors 2x2x2x3x3. Using those factors in different combinations results in sun gears of 36, 24, 18, 12, 9, and 8 resulting in 3:1, 4:1, 5:1, 7:1, 9:1, and 10:1 respectively. 6:1 and 8:1 ratios would have required use of prime factors 5 and 7 respectively, which would increase the ring gear tooth count by that many, which is impractical.
*I understand by definition gear ratios are integer ratios, but when reduced to the mechanical advantage factor, only evenly divisible ratios give integer results.
Red Alert Robotics
Unread 28-02-2016, 23:10
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: STEM Quiz #1
The one ratio which always bothers me is the 9:1. The sun gear has 9 teeth. Since the ring gear pitch diameter is the sun diameter plus twice the planetary diameter, working backwards from 72 teeth on the annular gear leaves 31 1/2 teeth on each of the planetary gears. I know it's possible to play some tricks with pitch diameter vs tooth counts, but I hope to be able to work around needing a 9:1 VP stage.
Gear ratios are always rational, that is ratios of integers, but not necessarily integers. It is possible to get close to the 6:1 and 8:1 integer ratios with a single stage 72t annular gear: with 10 teeth on the sun and 31 on the planets, a VP-compatible stage could be made with a gear ratio of 8.2:1; 14 on the sun and 29 on the planets would result in 6.14:1.
If you wanted to make a single "exact" 6:1 or 8:1 ratio stage compatible with VP, the first step would be to make a (most likely) 70t annular gear. Then your sun gears would be 10 and 14 teeth. If you were to do this, your "nearly identical to the standard" annular gears would probably be quite unpopular unless you found some clever way (e.g. color or a milled exterior similar to a U.S. quarter) to make them look quite unlike the 72t annular gear. I concur that this is not likely to be commercially viable, as the existing VP ratios provide a maximum gap of 40% (5:1 to 7:1) for a single stage. Above 9:1 (allowing multiple stages), the maximum gap is 25% (12:1 to 15:1 and 16:1 to 20:1) below 20:1 and 20% above that (50:1 to 60:1). There are few applications that cannot be designed around a 20% gap in capabilities.
Unread 29-02-2016, 00:40
MechEng83's Avatar
AKA: Mr. Cool
Re: STEM Quiz #1
Great point about the 9:1 requiring half-tooth planets. I probably will avoid those for anything that has significant torque needs to avoid shearing teeth.
Red Alert Robotics
Unread 29-02-2016, 07:46
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: STEM Quiz #1
Well done! Rep points awarded. (Remember, they're just dots!)
They aren't actually half tooth planets, but the teeth of these gears presumably had to be adjusted somewhat to make this work. While I haven't examined a 9:1 VP, my guess is that it has 32 slightly shortened teeth.
Unread 29-02-2016, 08:00
MechEng83's Avatar
AKA: Mr. Cool
Re: STEM Quiz #1
thanks!
I was going to assume 31 teeth and 3/4 tooth engagement. might be worth examining for future reference. either way it's not ideal.
Red Alert Robotics
