Go to Post The game objectives are still the same, get boxes into your scoring zone, stack approximately half of them, run for the top of the ramp. So lets sit down, shut up, and start building robots. - ChrisH [more]
Unread 05-03-2016, 12:49
angelah angelah is offline
FRC #3547
angelah is on a distinguished road
Swapping Festo solenoids out for Mead and we can't get them to work...
Because of the impact on the robot, the wiring on our Festo solenoids kept coming loose during practice. We ordered some of the Mead ones from Automation Direct instead (AVS-5121-24V.) They seem much sturdier, but the kids ran into some trouble getting them to work. They are 24V and we have the PCM to 24, same as with the Festo. We didn't change anything else. They don't switch at all, though they are lit.
If anyone could help us troubleshoot, I would appreciate it! We have tried everything we can think of.
Unread 05-03-2016, 13:19
vladtheimpaled's Avatar
vladtheimpaled vladtheimpaled is offline
FRC #0810 (The Mechanical Bulls)
Team Role: Electrical
vladtheimpaled is an unknown quantity at this point
Re: Swapping Festo solenoids out for Mead and we can't get them to work...
We had this problem a few days before bag and tag. The problem with ours ended up being that the little blue screws on our solenoid were not rotated into the correct position. Our lights on the solenoid lit up but the solenoid did not do anything else. I'm not sure exactly what position they're going to have to be but you might just want to rotate these until it works right. If your solenoid does not have these blue screws, it might be another type manual control structure which is not positioned correctly.
Unread 05-03-2016, 16:42
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
Also make sure pressure is on the P port. They are pilot operated.
Unread 14-03-2016, 19:18
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Did the Festo's have a plug? If so in the future just put a dab of clear silicone on the plugs and it will hold them from loosening. I've seen hot glue used but the silicone is flexible but still removable like the hot glue if needed.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
