Go to Post FIRST may very well be the healthiest drug on the market. - Herodotus [more]
Unread 05-03-2016, 20:35
GDB's Avatar
GDB GDB is offline
AKA: Garrett
FRC #2403 (Plasma Robotics)
GDB is a jewel in the roughGDB is a jewel in the roughGDB is a jewel in the rough
We only need half of this right?
Spacers suck...
Project Manger and Build Lead of Plasma Robotics - Team 2403 - 2015 season and 2016 season
Unread 05-03-2016, 20:41
Dibit1010 Dibit1010 is offline
FRC #0587
Dibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond repute
That's horrible, yikes! But on the bright side if that's an input sprocket you've get a higher ratio....
Unread 05-03-2016, 20:54
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Re: We only need half of this right?
That hurts the soul. Mind sharing how that happened, so I can make sure my team never ever does it?
Unread 05-03-2016, 21:14
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
We did that on our input arm. MiniCIM into a 30:1 VP, into a 20 tooth pinion mated with a 64 tooth gear on the arm. The miniCIM + VP is very close to shearing a tooth at stall. When you backdrive the mechanism by dropping the arm on top of a divider with the weight of the robot, it shears teeth before backdriving.
Our solution is a lot of work for me. We're switching to steel 10DP gears, that I have to machine down to the same face width and with a versakey pattern. If that doesn't work, we're switching to a set of the same steel gears I'm leaving at the full 1" face width. That should move the failure point to the output shaft itself.
Unread 07-03-2016, 10:36
Chris is me's Avatar
AKA: Pinecone
Why not "just" switch to 35 or even 25 chain? Gear drives for arms are going to have this problem a lot just because the full load of the arm will be carried by just 1 or 2 teeth at a time, versus several wider teeth in a chain setup. Learned this lesson the hard way in 2013 and 2014.
Unread 05-03-2016, 21:15
GDB's Avatar
GDB GDB is offline
AKA: Garrett
I will be honest... our bot is really tight this year.
And if our chain is loose, the motors will start to torque the gearbox and slowly grind the gear on each other, breaking the teeth off!
If you need more pictures of our bot I can give you some. We also have the reveal video. Our 4 drive CIMs are super close this year as well...
Unread 05-03-2016, 21:26
GDB's Avatar
GDB GDB is offline
AKA: Garrett
Oh I also forgot to mention there was an extra additional 1/16th inch spacer in the gearbox.
Unread 05-03-2016, 21:31
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
That half a gear is very well punctuated by the 72dpi 3042 by 4032 resolution.... Why can't we highlight image post combos yet?
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 07-03-2016, 10:32
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
You should mount that on a plaque and turn it into a team award.
The "what really grinds my gears" award goes to....
